Home > Message Board > Car Audio > Navigation Systems > Jensen NAV100 GPS Unit...issues
Author Thread: Jensen NAV100 GPS Unit...issues
Username: Rksturges
I have the Jensen NAV100 and I installed it yesterday. When I add a route and submit, it will work great. It gives me voice directions and I can view my progress on the map as I drive. When I just go into the map, it will not follow my truck. I have to keep hitting the position button on the remote to update where I am at. Any ideas?
Username: Macafee46
NJ
Post Number: 8
Hey Ryan,
I'm thinking about buying the NAV100 soon to go with my VM9021TS and I wanted to know if you figured out your problem yet? Have you had any other problems with the unit? Also i'm curious to know how do you turn on the navigation,I see a button on the headunit for everything else but not the nav?
Thanks for your help,I appreciate it
Username: Leew
XXXX!!WWWW, Yokosuka, ...
Holla Back Y...
Post Number: 1403
Ryan Sturges
You have to connect the "reverse" wire !
Username: Seiber84
I just wanted to verify that this NAV100
unit will work with a vm9311ts.
If so, are there any problems or issues with it that you don't like? What about the jensen headunits themselves?
Thanks in Advance,
Vince
Username: Scott06hemi
I can't find the NAV100 anywhere to buy. Anyone know of a place?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Car Audio > Navigation Systems > Jensen NAV100 GPS Unit...issues [ « Previous ] [ Next » ]
