Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Can i run 2 channels to one sub ?????...
Author Thread: Can i run 2 channels to one sub ????????please help?ive tried many times but no replies
120 oz. Double Stacked Strontium Magnets
Power Handling: 700 watts R.M.S.
Frequency Response: 20Hz - 500Hz
Efficiency: 92.7 dB
PHAT 2" Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3' Coated for Virtually No Cone Distortion
2.5" 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Mounting Dimensions: Depth; 5 5/8" Hole; 11 1/8" Diameter; 12 3/4"
Multi-connect Lug Lock Terminals
thats what i got now it says dual 4 ohm so if i were to get a 4 channel amp that runs say 300x4 at 4 ohms would i be able to put channel 1 & 2 to one sub for a total of 600 and 3 & 4 to the other for the same?
or would i have to use a 2 ohm amp or can you even run two channels to one sub??????????
if the subs ahve dual 4 ohm voice coils, hook each channel up to each voice coil. this will be a 4 ohm load...if it is dual voice coil, each coil will take 350 rms...if the amp is 300 RMS x 4 it will be good...but if its just 300 watts x4 it wont push'm very hard
well can i use a 2 channel amp instead.....i kinda already ordered it. i plan on putting 400 watts to each channel at 2 ohms. would that work or will it only be able to take 350 and is that goin to be loud?
Home > Message Board > Car Audio > Amplifiers > Archive through December 11, 2003 > Can i run 2 channels to one sub ?????... [ « Previous ] [ Next » ]
