Thread: DEI - Directed Audio D2400 |
Silver Member Username: Kklagge
Post Number: 366 Registered: Dec-04
| Posted on Friday, February 09, 2007 - 07:07 am: |
This amp any good? Does it do it's rated power? Anyone use one? I've read decent reviews in the past on directed amps. |
Gold Member Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 5650 Registered: Feb-06
| Posted on Friday, February 09, 2007 - 08:09 am: |
There allright. How much are you gonna spend on it? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4113 Registered: Dec-05
| Posted on Friday, February 09, 2007 - 12:31 pm: |
good/cheap. |
Post Number: 368 Registered: Dec-04
| Posted on Friday, February 09, 2007 - 12:40 pm: |
was only asking....just bought a Crossfire VR100D instead....MUCH better choice, I'm sure |
Post Number: 370 Registered: Dec-04
Was only curious....just bought a Crossfire VR1000D instead....MUCH better choice, I'm sure. |
Post Number: 371 Registered: Dec-04
| Posted on Friday, February 09, 2007 - 12:41 pm: |
oops....thought I canceled the 1st one...gotta get my post count up somehow huh? |
New member Username: Big_p_wit_tha_lincolns
Bad axe ,
Michigan
Usa
Post Number: 7 Registered: Dec-06
| Posted on Tuesday, February 20, 2007 - 02:51 pm: |
hey man ...listen i have the directed 2400 D it is the shizz i have 4 12's running at 2oms 800 watts rms i hit 134 db's and tha amp isn't even half way up. by far directed is the way to go .. i started out with the 600 ol school and sold it for $200 and it was used so the value doesn't go down some ppl just perfer directed amps alot more.. i have had 5 excessive noise tickets already and my amp can do way more .. peace out |
