Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Faulty Alpine IVA-D310 :-( Please help....
Author Thread: Faulty Alpine IVA-D310 :-( Please help.
Username: Chodecz
Post Number: 26
Hi guys,
I recently purchased a second hand Alpine IVA-D310 (http://www.alpine-usa.com/US-en/products/product.php?model=IVA-D310) it has a major fault though...
I installed the unit 100% correctly, and powered it up. It already had a CD in it which played fine, and all the other functions worked fine.. but when I went to eject the CD it made an ejecting noise for a split second (opposed to the usual long sound untill a disc is fully ejected) but the CD didnt come out! I then had to push the CD back in using another CD, then it made a brief loading noise and said 'disc loading error', then when I press the eject button the same happened as initially!
Anyway I eventually pulled the CD out with some small scissors. But now when I try to put a CD in, nothing grabs onto it and it just goes further and further in without being loaded! (
I purchased this unit second hand, and the seller wants a quote on fixing costs and will re-emburse me.
Does anyone know what the problem could be, and where/how I can get it fixed??
Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Faulty Alpine IVA-D310 :-( Please help.... [ « Previous ] [ Next » ]
