Home > Message Board > Car Audio > Subwoofers > Archive through February 05, 2007 > Archive through February 05, 2007 > ~Tell me what you think~
Author Thread: ~Tell me what you think~
Username: Qcsfinest
Charlotte, North Carolina
Post Number: 366
ok im rebuilding my system and i wanna kno what you think.
kicker ss65.2 components (front)
kicker ks65 (rear)
kicker kx650.4 or kicker kx850.4 (Which one?)
kicker zx1000.1 or zx1500.1(only if i can find a 12"xxx)
I was thinking the 12"xxx because i figured it would sound close to my sx ported but have great sq. if i cant find it i need some suggestions.......maybe a Q,
Username: Snarl2004
Post Number: 172
speakers look good
in my opinion you should get either the bl or the HD3 and use the zx1000.1 amp
Username: Qcsfinest
Post Number: 368
dont want the bl. This is gonna be an SQ setup but loud.
Username: Snarl2004
Post Number: 174
q sounds good then
Username: Qcsfinest
Post Number: 370
will the kicker speakers and kx650.4 work or do i need to move up to the kx850.4?
Username: Qcsfinest
Post Number: 371
anyone?
Username: Snarl2004
Post Number: 177
Username: Ars88
P.I.M.P , Pakistani/In...
Post Number: 436
650 should be fine
Home > Message Board > Car Audio > Subwoofers > Archive through February 05, 2007 > Archive through February 05, 2007 > ~Tell me what you think~ [ « Previous ] [ Next » ]
