Home > Message Board > Car Audio > EQs and Crossovers > Alpine 9830 Built in EQ Parametric Qu...
Author Thread: Alpine 9830 Built in EQ Parametric Quick Question
Username: Riceboy54
Post Number: 8
Hello,
I just have a question about how the Parametric EQ works. Its 4 band with 3 adjustable Q's.
The Q seems to determine effect on the and 3 being the least. Am I correct on this?
Am I only able to pick one frequency out of a band to adjust?
Example, Band 3 gives me 2k, 4k, 6k. When I touch 4k and set on say -3db then move to 6k, it continues from -3db and not from 0 which leads me to believe I can only choose 1 of those 3 frequencies to adjust. Meaning I can only have 4 different adjustments, 1 for each band? Is this correct?
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > EQs and Crossovers > Alpine 9830 Built in EQ Parametric Qu... [ « Previous ] [ Next » ]
