Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > 2.2V vs. 5V pre amp
Author Thread: 2.2V vs. 5V pre amp
Username: Nkknutson
Post Number: 84
Is there a big difference i'm looking at getting a new deck and did not know if there is a big difference between the two. I'm going to have one 12" sub and speakers that run off an amp. thanks for the advice
Relevant Product Info
Username: Nd4spd18
Post Number: 217
With the 5 volt HU there will be less noise in your system. When you turn it up loud there will be less static. Noise level is the only thing affected be preout voltage.
Username: Adddisorder
West palm, Florida
Post Number: 2967
you wont be able to notice a difference
Username: Nkknutson
Post Number: 85
so not worth the one or two hundred dollars more?
West palm, Florida
Post Number: 2970
personally i would get one with higher pre outs but really you shouldnt notice a difference, just get a pioneer premire
Username: Justblomekthanx
Depends on your set up n RCA's. Dont go cheap on your RCAs or amp install kit. But Id go for the higher pre volt HU. Just in case you wanna upgrade your subs/speakers/amp and use 2 amps.
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 11466
"Dont go cheap on your RCAs or amp install kit"
RCA=Gotta be good
aik=wire is wire
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > 2.2V vs. 5V pre amp [ « Previous ] [ Next » ]
