Home > Message Board > Car Audio > Navigation Systems > Getting navigation to work
Author Thread: Getting navigation to work
Username: Hutch04
hello.. i have a kenwood dvd/navigation and i jus got it all back together from someone trying to steal it.. i have never had navigation hooked up and working and was wonding what all i needed to do to get it to work.. thanks
Relevant Product Info
Username: Qbenjamin
Florida
Post Number: 249
if you know how to install a common head unit, then it should be no problem for you to hook up a navigation system. Most of the time the only problem lies with hiding all the wires and the hide-away unit.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Navigation Systems > Getting navigation to work [ « Previous ] [ Next » ]
