Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > HELP with deck at home
Author Thread: HELP with deck at home
Username: Logic789
Hello, I have a regular cassete car deck that I want to hook up in my house. I know you need something like a 110 volt to 12 volt converter but I looked it up and i only saw those cheap adapters. I dont know where to get one I want the ones that has the output so i can put the red and black wires straight in. someone please help me out. thanks.
Username: Basssquared
Post Number: 121
it would be so much easier to buy a boom box lol
Username: The_image_dynamic
San Diego
Post Number: 215
You need something like this and lol Ray:
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10107/s-10101/p-100000181123/med iaCode-ZX/appId-100000181123/Pr-p_CATENTRY_ID:100000181123
Username: Logic789
thats exactly what i need but that one outputs 13.8 volts i need one that outputs 12 volts.
Username: Logic789
HELP
San Diego
Post Number: 247
The one I posted will work fine. That's why I posted it in the first place. Everyone on here that is running a HO alt and/or extra batteries is pushing 14.4 volts or more to their head units/amps. The one I posted outputs 12.8 volts under load.
Username: Logic789
The one that you posted is out of stock till the 28th, do you know of any other site that sells it or anything similar to it. I'm looking to get one very soon.
Username: Logic789
help me out please!!!
San Diego
Post Number: 320
http://www.electronicsoutpost.com/dcacinverters.htm
San Diego
Post Number: 321
Sorry that one was backwards. You could get this one and hack the lighter connector off and then wire your radio direct:
http://www.brandsonsale.com/5amactodcad.html
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > HELP with deck at home [ « Previous ] [ Next » ]
