Jensen Vm9311
Username: Nickjudkins
I baught a Jensen VM9311 today and I have a few questions about it.
1.When I have the aux/dvd/cd modes on my sub does not work.
2.Can you change the backrounds on the screen?
3.Can you hook a Zune up to the Media Module?
Thanks!!!
Username: Wilo_21
FPO, AE USA
Hello i would like to know the bypass code for the VM9311. i need it so i cant watch vedios when the car is driving. Thanks Kevin
Username: Miles_hood
Tyler, Texas US
Post Number: 140
there is no code .. you have to take the ebrake wire on the harness and connect that to the ground wire...}
yes there is a code...
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
guarenteed to work.. why? because i found it online and it worked for me!
