Thread: I have a question about my subs and amp. |
New member Username: Aaron_toler
Post Number: 2 Registered: Jan-07
| Posted on Saturday, January 13, 2007 - 09:10 am: |
I have two 12 inch blaupunkt velocity 1350 watts max each subs ( i think they are 4 ohms each too if that helps any) and a little 2 channel power acoustic 360 watt amp. Would i get more power if i put both of my subs into one channel or would i screw something up. Will it damage anything? |
Post Number: 3 Registered: Jan-07
| Posted on Saturday, January 13, 2007 - 09:38 am: |
It says on the amp 65 rms per channel and 150 rms bridged mono. So what will it do if i bridge it to one channel it wont mess anything up will it. Thanks to who helps me. |
Gold Member Username: Tjmutlow
Post Number: 3456 Registered: Sep-05
| Posted on Saturday, January 13, 2007 - 11:56 am: |
yes if those are single 4 ohm, that amp is stable 4 ohm bridged, and you would put a 2 ohm lod, and not enough power for those subs.You prob will burn that amp up running it bridged 2 ohm load |
Post Number: 4 Registered: Jan-07
| Posted on Saturday, January 13, 2007 - 01:55 pm: |
So do you think I should juss get a bigger amp. |
