Thread: Subwoofer ohms load question |
Silver Member Username: Spandmh1
Tunnel hill,
Ga
Usa
Post Number: 110 Registered: Oct-06
| Posted on Thursday, January 11, 2007 - 05:26 pm: |
what that website you go to that shows u the different ohm loads? u know, the one that shows u how to hook the subs up? |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 2303 Registered: Jul-06
| Posted on Thursday, January 11, 2007 - 05:28 pm: |
http://www.the12volt.com/caraudio/woofer_configurations.asp there u go sir |
Tunnel hill,
Ga
Usa
Post Number: 111 Registered: Oct-06
gracias bro |
Fi SSD
Post Number: 2304 Registered: Jul-06
| Posted on Thursday, January 11, 2007 - 05:30 pm: |
not a problem question for you or anyone whats the site that designs boxes for you? or any box maker thing. im bored and want fool around with one and see what happens.lol |
New member Username: Brayden
Post Number: 3 Registered: Dec-06
| Posted on Thursday, January 11, 2007 - 07:08 pm: |
question up. for the ohm loads do you need teh wiring that is rated for that many ohms. like if your gonna wire it for a 2 ohm load do you need 2 ohm wiring? just thought id check... |
