Thread: Question about memphis amp |
Bronze Member Username: Razzeldazzel06
Post Number: 21 Registered: Jan-07
| Posted on Wednesday, January 10, 2007 - 09:18 pm: |
i went to a store the other day looking to get a 12 inch image dynamic idmax and an 1100 memphis d amp. I asked him if i needed a fan for the amp because it is going into a small closed compartment and he said no because these amps are so good they do not get hot. Then he said i do not need a new alternator or anything like a capcitor or anything because this memphis 1100d amp is so powerful and well built. Is this all true or should i look somewhere else? |
Gold Member Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2086 Registered: Nov-05
| Posted on Wednesday, January 10, 2007 - 09:36 pm: |
well what kind of car do u have, bc i have a250 rms speaker amp and a 1200 rms sub amp and im not usin a cap or new alt.. |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 1716 Registered: Mar-06
| Posted on Wednesday, January 10, 2007 - 09:47 pm: |
that memphis will only pull about 70 amps, so stock should be ok. |
Silver Member Username: Trey4sports
Post Number: 254 Registered: Sep-06
| Posted on Wednesday, January 10, 2007 - 10:09 pm: |
if ur lookin to run your system with car off tho i would recommend a kinetik HC1400 |
Post Number: 23 Registered: Jan-07
| Posted on Wednesday, January 10, 2007 - 10:11 pm: |
i have the new dodge nitro with premium sound system. |
Post Number: 263 Registered: Sep-06
| Posted on Wednesday, January 10, 2007 - 11:09 pm: |
ohh well congrats man, u like it? i know its a premium sound system but exactly what speakers are they ? i think dodge uses infinity? |
Post Number: 24 Registered: Jan-07
| Posted on Wednesday, January 10, 2007 - 11:27 pm: |
thanks..yea there infinity..sounds nice just needs some more bass..u think i should get a high output alt |
Post Number: 269 Registered: Sep-06
| Posted on Wednesday, January 10, 2007 - 11:35 pm: |
nope, im guessing your jsut into SQ you dont want anything that gets super loud, just add more bass to daily driving? well i suggest you get a JL W6 and JL 500/1 to go with it and you will be in excellent shape very good sounding setup. if you can wire it up yourself and dont need to buy locally i suggest a Fi SSd and run a good 800 rms amp. good luck |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3865 Registered: Dec-05
| Posted on Thursday, January 11, 2007 - 01:02 pm: |
any amp can get hot, but memphis is really good |
