Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Ever Use Massive?
Author Thread: Ever Use Massive?
Username: Alexv305
Tavernier, FL
Post Number: 490
I am about to buy a Massive Audio P3000.1. I need to know if anyone has ever used one. The amp measures 38 inches on the Massive Website. On Amp Guts it says it requires a 200 amp external fuse. That seems somewhat small. I hope its not way underrated. Massive says it does 3000w RMS @ 2 ohms at 14.4 volts. Has anyone actually used one? I need to know fast...
Username: Adddisorder
West palm, Florida
Post Number: 2714
you actually need 14v+ like it says to get the 3000rms so it is accuratly rated. really i dont think your going to notice any difference from this and if you had your orion2500d at .5ohm
Username: Trey4sports
Post Number: 248
i just bought mine i noticed on their site it has it listed as 2680 watts? so im guessing thats at 12 volts and 3 grand is at 14
Username: Logan__tille
[:-]15 Wangers Club[:-]
Premier Member
Post Number: 4484
Ask BerneyMac he has 2 of them.
Post Number: 276
yeah berns system is awesome no doubt
Username: Bernymac
Cambodian
Post Number: 1732
Very nice amps, they push my hd3's really nicely at 2k total. 1k to each sub. Shipping one amp out bc it was broken during shipping. But a great amp. I also like that you can do 1500rms x 2 at 1ohm.
Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Ever Use Massive? [ « Previous ] [ Next » ]
