Thread: Refurbished amplifier? |
Bronze Member Username: Jaguar600
Post Number: 71 Registered: Jul-05
| Posted on Monday, January 08, 2007 - 02:14 pm: |
Is it ok to buy a refurbished amplifier? its a Kenwood KAC-9102D |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 2701 Registered: Jan-06
| Posted on Monday, January 08, 2007 - 02:37 pm: |
generally refurbished is new internals in an old case however kenwoods suck so dont buy one. whats youre budget and power needs? |
Post Number: 72 Registered: Jul-05
| Posted on Monday, January 08, 2007 - 05:40 pm: |
hmm around $130 or less and at least 300 watts rms.. I had a bazooka el1500 but it burnt out |
Gold Member Username: James1115
Use a simple...
Post Number: 8694 Registered: Dec-04
| Posted on Monday, January 08, 2007 - 06:08 pm: |
save more if you can, you get what you pay for in car audio. I would buy a good used amp over a cheap refurbed amp. |
West palm,
Florida
Post Number: 2712 Registered: Jan-06
| Posted on Monday, January 08, 2007 - 06:21 pm: |
you could buy a PG x400.1 on ebay for cheap and they are nice amps |
Silver Member Username: Tdawg30
Ohio
Post Number: 840 Registered: Jun-06
| Posted on Monday, January 08, 2007 - 07:29 pm: |
yeah I have a x400.1 that I got for 95 shipped from a guy on caraudio.com and it is the sweetest 95 ive ever spent. I would have payed 130 for it no problem. Im sure you can find one for around that price, just look around. |
Silver Member Username: Qbenjamin
Florida
Post Number: 170 Registered: Nov-06
| Posted on Monday, January 08, 2007 - 07:47 pm: |
Refurbished amps are great if you want to get something better than used and save money while doing it. Just keep in mind that nothing beat's BRAND NEW! |
Silver Member Username: Tremor1127
Post Number: 656 Registered: Aug-06
| Posted on Monday, January 08, 2007 - 07:58 pm: |
yes, PG x400.1 is a good amp... |
Post Number: 73 Registered: Jul-05
| Posted on Monday, January 08, 2007 - 08:13 pm: |
can you clarify on what brand a x400.1 is please lol thanks |
Post Number: 74 Registered: Jul-05
| Posted on Monday, January 08, 2007 - 08:15 pm: |
never mind its a phoenix gold.. can you guys recommend any others? I am checking out the x400.1 now |
West palm,
Florida
Post Number: 2715 Registered: Jan-06
| Posted on Tuesday, January 09, 2007 - 12:23 pm: |
kicker kx400.1 if you need it at 2ohm |
Post Number: 75 Registered: Jul-05
| Posted on Tuesday, January 09, 2007 - 02:29 pm: |
hmm ok well do you guys know of any amps that can handle 1 ohm that are decently priced? |
Florida
Post Number: 175 Registered: Nov-06
| Posted on Tuesday, January 09, 2007 - 03:03 pm: |
Orion |
Florida
Post Number: 176 Registered: Nov-06
| Posted on Tuesday, January 09, 2007 - 03:04 pm: |
what power range are you looking for? What is your budget? |
Use a simple...
Post Number: 8719 Registered: Dec-04
| Posted on Tuesday, January 09, 2007 - 09:28 pm: |
I have a orion hcca 259g4 it does stereo 50x2@ 4 ohms 100x2@ 2ohms 200 x 2 @ 1 ohm and 400x2 @ 1 ohm Mono it does 200 x 1 @ 4 ohms 400x1 @ 2ohms 800x1 @ 1 ohm all at 12 volts. This is a highly underrated class a/b competition amp. |
Use a simple...
Post Number: 8720 Registered: Dec-04
| Posted on Tuesday, January 09, 2007 - 09:29 pm: |
E-mail me if you are intereested jlongo1115@aol.com |
Silver Member Username: Teddy21
Ann Arbor,
MI
Post Number: 391 Registered: Feb-06
| Posted on Tuesday, January 09, 2007 - 09:54 pm: |
try a bp300.1 by JBL you can usually find em on ebay for under $100 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3855 Registered: Dec-05
| Posted on Wednesday, January 10, 2007 - 12:54 pm: |
damn, a refurbished kenwood, i hope that's a joke |
