Thread: Amps on Box?? |
Bronze Member Username: Skibum12189
Post Number: 43 Registered: Mar-06
| Posted on Sunday, January 07, 2007 - 08:34 pm: |
How bad would it be to mount my two kicker amps on top of my triple sub box. A kid told me elemental designs covers it under warranties. The amps are brand new and its three 350-400 watt rms sealed box subs..... Tell me what you think bc itd look 100x cooler in my opinion |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 2084 Registered: Jul-06
| Posted on Sunday, January 07, 2007 - 08:46 pm: |
nah dont mount on the box, put them beside the box or in front of but not on. could damage the amp |
Post Number: 45 Registered: Mar-06
| Posted on Sunday, January 07, 2007 - 09:03 pm: |
what if i built an extra piece on top to mount em on, like a regular rectangle box, but then like a 45 degree angle piece to mount em angled to the rear of the car? |
Fi SSD
Post Number: 2086 Registered: Jul-06
| Posted on Sunday, January 07, 2007 - 09:09 pm: |
thatll help, just dont mount them directly on the box cause it can damage them. but if you add more of a "buffer zone" it'll be better. ive heard, i dont know this for a fact, but if you can get rubber and put it under the amp or something it will reduce the vibrations coming onto the amp. i dont know if this is true or not but it does sound kind of logical. someone else will have to tell you about that tho. |
Gold Member Username: Logan__tille
[:-]15 RE XXX[:-]
Post Number: 4378 Registered: Feb-06
| Posted on Sunday, January 07, 2007 - 09:58 pm: |
could you put the amp somewhere else? |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 2321 Registered: Jan-06
| Posted on Sunday, January 07, 2007 - 10:36 pm: |
An amp needs a solid mount. The reason mounting an amp to a box is a bad idea is because the flex of the panels. This can cause broken solder joints and other electrical component in the amp to fail. Think about this, all it takes if for ONE single leg on an output fet to break and you will lose the rest of your amp. The output stages fail in a cascading effect and this will be costly. Make a piece of MDF the sidze of the amp you want to mount. Find a spot closest to any internal bracing, bolting the panel down first then the amp to it. If at all possible, mount it to the top or to a whole different place. Keep us posted... Polo.. PS-Adding a layer of rubber will not help with frlex, maybe with vibes a bit but remember most vibration we deal with it airborn, so the rubber may even amplify this effect. |
Post Number: 46 Registered: Mar-06
| Posted on Sunday, January 07, 2007 - 10:40 pm: |
What if i built my box and everything with like a rectangle and then put like a big amp rack on top and put dynamat or some edead under the carpet and then screwed my amps onto that mdf. Would that sufficiently stop the flex or is it still not worth the risk |
Bronze Member Username: Jeromebaker
Post Number: 44 Registered: Dec-05
| Posted on Monday, January 08, 2007 - 02:49 am: |
If you use good quality thick fiber board you should be fine. I've done it with every amp I've ever owned 6 years and going and none have fried/broke because of it. Your amp is getting almost as much vibration if it's close to the box anyway. I've heard horror stories of parts being rattled loose on a box some guy built out of an old wal-mart dresser, but I haven't had problems. Just don't go mounting it to some rice-board box and you should be fine. The key is to use good wood. Mount an extra board if you want to protect it further. |
Fi SSD
Post Number: 2131 Registered: Jul-06
| Posted on Monday, January 08, 2007 - 05:23 pm: |
"PS-Adding a layer of rubber will not help with frlex, maybe with vibes a bit but remember most vibration we deal with it airborn, so the rubber may even amplify this effect." i lose, someone suggested it to someone else and i read it and it souded logical but polo is a genius. thanks for clearing that up for me polo |
