Thread: Jl amp and sub |
New member Username: Jacobd
Seattle,
WA
U.S.
Post Number: 3 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 05:17 pm: |
I am pretty sure I can get a nice 1000/1 and a 13w7 all for under $1,000 if I shop around but is that one subwoofer enough or do you need two? I was thinking if I can't find a nice 1000/1 I could go with a 500/1 and a 10w7. I am not looking for too much power but definitely would like to have it incase I need it once in a while. I am definitely about quality so if someone has some good suggestions about a setup even if it breaks $1,000 I'd be more than grateful. Must be JL. |
Silver Member Username: Devastation101
Audioque SD2.5-ville,
HENDERSON, NC
US of A
Post Number: 773 Registered: Feb-06
| Posted on Sunday, January 07, 2007 - 05:44 pm: |
If i'm not mistaken, the W6 has a better sound quality than the W7. Someone help with this one! |
HENDERSON, NC
US of A
Post Number: 774 Registered: Feb-06
| Posted on Sunday, January 07, 2007 - 05:45 pm: |
BTW, for $1000, there is a lot you can buy that would be better than that JL setup... |
Silver Member Username: Dsmith07
LaGrange,
NC
US oF A
Post Number: 406 Registered: Jun-06
| Posted on Sunday, January 07, 2007 - 06:11 pm: |
yep w7 supposed to be for spl and w6 for sq |
Seattle,
WA
U.S.
Post Number: 4 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 06:17 pm: |
Trell you have some examples? |
Silver Member Username: Trey4sports
Post Number: 236 Registered: Sep-06
| Posted on Sunday, January 07, 2007 - 06:19 pm: |
i like they way both sound in person, but the W6 is weak in the low end end. if your straight SQ go for the W6, and if you just wanna sound good and are not lookin to compete or anything W6 will be plenty of bass. |
Seattle,
WA
U.S.
Post Number: 5 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 06:26 pm: |
Which one of the two subs will pick up low bass??? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3844 Registered: Dec-05
| Posted on Sunday, January 07, 2007 - 07:10 pm: |
jacob i love jl but seriously, if you're doing a 1 sub setup for 1k you can get almost the same SQ, more output with less money. I'd try a Fi Q and a 1000-1500w rms amp such as kicker kx 1200.1 You will love it |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 1664 Registered: Mar-06
| Posted on Sunday, January 07, 2007 - 07:21 pm: |
Personally my W6 12" gets low. And it sounds great doing it. In reality how often do you drive around with your subs slamming. Not all the time. But low to mid volume the bass is solid. and when you twist it, it riveled my L7. So like ^^^ said. if you want to be noticed W7. If you want to be admired, W6 |
Seattle,
WA
U.S.
Post Number: 6 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 07:36 pm: |
Someone once suggested off ecoustics to mix it up a little. I don't deny kicker they are a good brand but their prices vary so much accross markets it's rediculous. JL is able to hold their prices relatively well regardless of where you buy them, which is a good sign. What would in your opinion go good with a 1000/1 amp? |
Boston South,
MA
Post Number: 1667 Registered: Mar-06
| Posted on Sunday, January 07, 2007 - 07:39 pm: |
2- W6 12"s |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 2087 Registered: Jul-06
| Posted on Sunday, January 07, 2007 - 09:13 pm: |
2 dub6's would a very nice system. id take it everyday of the week. but yea trell, dub6 is sq, dub7 is more spl. |
Post Number: 3849 Registered: Dec-05
| Posted on Monday, January 08, 2007 - 09:51 am: |
one of the greatest SQ system... w6 with jl 1000/1 if you have the money go for it |
Gold Member Username: Suleman36
Post Number: 4172 Registered: Feb-05
| Posted on Monday, January 08, 2007 - 12:41 pm: |
Best combo for everday SQ driver hands down is : JL 500/1 and a 12w6v2 sealed to spec. 18db @ 80hz LPF 12db @ 100hz HPF Will send chills up your spine once setup right. |
