Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Whats better
Author Thread: Whats better
Username: Mike_16
Burlington, Wisconsin
Us
Post Number: 189
would 2 12s alpine type r with a hifonics xx zeus amp be better than 2 re sx 12's subs with that amp ?
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 10941
nope
Username: Mike_16
Us
Post Number: 190
wouild those re with a nice box be loud with that amp or is there a better amp that will be louder than that to push them for like 400 bucks
Huntsville, Alabama
U.S.
Post Number: 10944
they are dvc 2ohm?? or 4ohm??
see if you can find a Kicker kx2500.1 or Zx2500.1, Orion 2500D. RF T2001Bd..or something that does 2000+rms
Username: Mike_16
Us
Post Number: 191
yea there 2 ohms but wouldnt i need a big 3 fro those subs and an extra batt and stuff would 2 guage wirieng work cuase thats what i have or should i get bigger
Huntsville, Alabama
U.S.
Post Number: 10947
yep...
big 3
HO alt
extra Batt
2ga should be fine...bigger is always better but the 2 should work....and no matter how you cut it...ur gonna have to upgrade ur charging system to run those subs the way they need to be ran
Username: Mike_16
Us
Post Number: 192
yea my lights dim now but dam thats the prob i have no idea how to hook up the big three or and extra batt i just know how took hook up a regular system but what do u mean charging sytsem
Huntsville, Alabama
U.S.
Post Number: 10949
http://wickedcases.com/caraudio/charging.html
Username: Mike_16
Us
Post Number: 193
well i figured out that i have mu system hooked up to 4 ohm load and my amp does 550 rms at 4 ohms and if i think thats pretty loud then how loud would i think that system would be with that kicker amp? im guessin pretty da.m loud so how much would those subs with an amp and a big 3 cost to do ? can someone try and calculate that all up i found 2 re sx on ebay for 400 for 2 so i was thinkin that was a good deal
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3848
search iraggi on ebay for HO alt
for wires go to www.knukonceptz.com
there you go
Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Whats better [ « Previous ] [ Next » ]
