Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Setup help regarding two 10" Alpine t...
Author Thread: Setup help regarding two 10" Alpine type R sub's
Username: Alaphamale
As you can probably guess from the title, I need some help regarding what amp(s) would be best to use.
Im looking to get two 10" Alpine type R sub's, (im sure that anyone worth getting advice from will already know their spec)
Ideally I would like to get two Amp's but I am unsure what one's would be best to get, so this is where I need some suggestion's.
The sub's will not be boxed, as I am having a custom boot install, there will be one in each top corner of the boot behind the seat's, facing down and inward's (that's the best way I can think to describe it) with either one amp in the middle or two under each sub.
What would be the best amp(s) to run this setup? and is it worth getting any power capacitor's (if so, what power rating and make)
Thank's in advance for any help,
Alphamale
Username: Adddisorder
West palm, Florida
Post Number: 2667
depends on what the voice coil impeadance is. look into getting the alpine mrd-1000 or whatever it is its a decent amp
Username: Nyyfan13
Fi SSD
Post Number: 2039
hold on, so the sub wont be in a box? free air?
and no cap, not needed:
http://www.wickedcases.com/caraudio/capacitors.html
and we need the voice coil impedence like dope said. cant give you a correct amp without knowing that.
Yes there won't be a box as such, they will be in a custom surround however. Even though it will be a tight custom fit, it's probably best to describe them as being in 'free air'
Well at least I know a capacitor is not needed, Just left with the decision on the amp(s) I may yet be purchasing two Alpine type X instead, if I can find a good enough deal. However for the time bing I will stick to the original idea of two type R's.
Any more help regarding the Amp would be appreciated.
Thank's in advance,
Alphamale
Username: Smittty
Silvis
just get 1 600watt+ amp because type r speakers are only 300 watts rms i would wire them together in a 4 ohm parallel series then you will be fine
Username: Logan__tille
[:-]15 RE XXX[:-]
Post Number: 4284
type Rs are 500 watts??
Are you sure about that, as I understood it type R's were 500W RMS with a peak of 1500W
[:-]15 RE XXX[:-]
Post Number: 4300
Yea they are, i think he ws talking about the older tyre r's.
Username: James1115
Use a simple...
Post Number: 8657
I wouldnt give them 500 watts free air!
West palm, Florida
Post Number: 2678
i woulndt run them free air or IB at all. a box will give you the best sound
I don't have the option of boxing them, I know they would sound better but the type of install and the boot space will not allow for it.
Alphamale
[:-]15 RE XXX[:-]
Post Number: 4309
What kind of car do you have? When you have subs free air its like not even having a sub. You can barly hear any bass.lol
Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Setup help regarding two 10" Alpine t... [ « Previous ] [ Next » ]
