Thread: Needing a 2 channel AMP |
New member Username: Stoop_ed
Post Number: 4 Registered: Jan-07
| Posted on Friday, January 05, 2007 - 02:34 am: |
Looking for a 2 channel amp that will push enough power for my L5 15" solobaric. Dual 2 ohm...... |
New member Username: Tom14pep
Post Number: 2 Registered: Jan-07
| Posted on Friday, January 05, 2007 - 03:22 pm: |
i would get a mono amplifier. They are more stable when connected to a subwoofer than a 2 channel. make sure the amp you buy puts out the most power at 2 ohms, not 4 ohms or 1 ohm |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 2666 Registered: Jan-06
| Posted on Friday, January 05, 2007 - 03:37 pm: |
tom you dumb a s s stop giving bad information he needs an amp that does its power at 1 or 4ohm he has 1 sub that is D2ohm you can only wire to 1 and 4 ohm |
Post Number: 6 Registered: Jan-07
| Posted on Saturday, January 06, 2007 - 12:38 am: |
Anyone has any good amps for sale?? |
Gold Member Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2058 Registered: Nov-05
| Posted on Saturday, January 06, 2007 - 01:13 am: |
so why not get a mono amp?? |
Post Number: 7 Registered: Jan-07
| Posted on Saturday, January 06, 2007 - 02:29 am: |
Actually any amp that will work will do. I dont really know much and was just told to look for a 2 channel amp |
Gold Member Username: Tjmutlow
Post Number: 3445 Registered: Sep-05
| Posted on Saturday, January 06, 2007 - 10:00 am: |
that is fine ran at 4 ohms, how much do you want to spend. |
Gold Member Username: James1115
Use a simple...
Post Number: 8649 Registered: Dec-04
| Posted on Saturday, January 06, 2007 - 10:13 am: |
someone was selling a jbl bp 1200.1 for$200 thats a good deal. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3827 Registered: Dec-05
| Posted on Saturday, January 06, 2007 - 11:47 am: |
you need 800w rms at 1 ohm or 4 ohms. Choose the amp you want. |
Post Number: 8 Registered: Jan-07
| Posted on Saturday, January 06, 2007 - 01:40 pm: |
Do you know how long ago the jbl was for sale? I cant find the listing for it |
