Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Needing Help or advice for solorbaric...
Author Thread: Needing Help or advice for solorbaric L5 15"
Username: Stoop_ed
I was given a 15" solobaric L5. What is a good amp to run this thats not too expensive? Thanks in advance
Username: Jaackdeth
United States
Post Number: 745
Dual 2 or 4 ohm?
Username: Zbate
Sadd, Texas
United states
i would go with a zx 750.1 depending on if its dual 2 or 4 ohm
Username: Stoop_ed
it's a dual 2 ohm.... Thanks
Username: Stoop_ed
Any suggestions??
Username: Logan__tille
[:-]15 RE XXX[:-]
Post Number: 4285
How much is expensive?
Username: Stoop_ed
I didnt want to spend over $200.00. Will that be possible for a decent amp?
Username: Tjmutlow
Post Number: 3443
you need a 1 ohm stable amp, look at the hifonics line
[:-]15 RE XXX[:-]
Post Number: 4377
Whats the rms on it?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3850
i think is 750w rms. I'd try hifonics bxi 1206D or any amp in the 750-1000w rms at 1 ohm range
Username: Skibum12189
Post Number: 58
I'm selling my Hifonics 1206D, it pushed 1200 watts rms at 1 ohm and 900 watts rms at 2 ohms. Umm...haha hifonics overrates all their stuff, so its probably pushing about 900 rms at 1 ohm and 700 at 2 ohms
you'd be safe pushin 900 to a L5, just turn the gain down. I'd be happy with 160 shipped
Post Number: 59
BTW, the L7 series is 750 rms....the L5 series is 600 rms, but the 15" can take 750....haha im a little biased, but 900 rms would be perfect...
Username: Stoop_ed
Post Number: 9
whats the condition? Do you have pictures?
Home > Message Board > Car Audio > Amplifiers > Archive through January 13, 2007 > Needing Help or advice for solorbaric... [ « Previous ] [ Next » ]
