Thread: Hifonics BX2005D will it match nicely?? |
New member Username: Hgill05
CA
Post Number: 2 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 11:09 pm: |
I got 2 Kicker L7 15" 4 ohm subs and i am looking for an amp that would match correctly with it. I ran upon the hifonics amp for $260 which is: 1 x 2000 Watts @ 1 Ohms 1 x 1300 Watts @ 2 Ohms Super D-Class Amplifier Topography High End Performance Amplifier Mono 1 ohm Mode Ultra-Fi Mosfet Outputs Is this a reputable amp and will it be a good match for my subs? |
Gold Member Username: James1115
Use a simple...
Post Number: 8629 Registered: Dec-04
| Posted on Tuesday, January 02, 2007 - 11:13 pm: |
some may say it is but I dont think so. It is unreliable and overrated. Don't expect more then 60% of its rated power form it, 70% AT BEST! |
New member Username: Jnralp00
Post Number: 8 Registered: Nov-06
| Posted on Saturday, January 06, 2007 - 09:41 pm: |
Unreliable? How do you figure? Sure they are a little overrated... But still well built, solid amps. I love my BXi2006d. |
Silver Member Username: Devastation101
Audioque SD2.5-ville,
HENDERSON, NC
US of A
Post Number: 713 Registered: Feb-06
| Posted on Saturday, January 06, 2007 - 10:49 pm: |
They are very solid amps, but like grocery said, a little overrated. I would look for another amp that does a guranteed 2000 watt at 1 ohm. |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1118 Registered: Mar-04
| Posted on Sunday, January 07, 2007 - 01:44 am: |
They're relatively accurately rated. The most recent benchtest I saw on a bx2005 was 1802w at 14.4v. I'm no math major, but I'm gonna say that's right about 90% of rated power. And FWIW - even if it DID do 2000w there would be no audible difference whatsoever. Maybe a couple tenths of a dB. |
Silver Member Username: Mygame5982
Comp Vr H-TOWN,
TEXAS
US
Post Number: 945 Registered: Jan-06
| Posted on Sunday, January 07, 2007 - 02:57 am: |
itll push em |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3829 Registered: Dec-05
| Posted on Sunday, January 07, 2007 - 10:58 am: |
wire them at 1 ohm. James hate brutus line but that's his choice, he has some base to talk that way. For me, hifonics brutus is the lowest you can go for decent quality when buying an amp |
