Thread: Car amp to home stereo |
New member Username: Bkrboy9927
Post Number: 1 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 03:49 pm: |
i have a 1200 watt sony xplod 2 channel car amp and i was wondering if there was any way to hook it up to my home stereo without blowing it. |
Silver Member Username: Arande2
400dB could probably d...,
4000 isnt ev...
100,000dB FU...
Post Number: 557 Registered: Dec-06
| Posted on Tuesday, January 02, 2007 - 03:54 pm: |
Yes there is. You have to get a power supply converter though to convert to the correct voltage. It also has to be rated to handle the amps your car amp will pull. Why are you hooking it up to your stereo? Do you want louder sound or something? |
Post Number: 2 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 04:14 pm: |
ok..ya i just got a whole system and i dont have a car just yet and i want to hear how good they sound..could i use a power supply from a computer? |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 2625 Registered: Jan-06
| Posted on Tuesday, January 02, 2007 - 04:36 pm: |
no really its not worth the trouble power supplys are expensive. and a PC one will probly not have enough amps |
New member Username: Cookies2
Temple,
TX
United States
| Posted on Monday, January 08, 2007 - 11:51 am: |
where could i get a power supply converter for my car amp and how much would it cost. its a 300 WATT Visonik amp |
Platinum Member Username: Project6
Post Number: 12293 Registered: Dec-03
| Posted on Monday, January 08, 2007 - 12:04 pm: |
Don't do it. It is not worth the money and trouble. Sell the amp and get yourself a receiver for home audio. |
Gold Member Username: Bestmankind
Fi Audio BTL
Post Number: 8900 Registered: Oct-05
| Posted on Monday, January 08, 2007 - 12:22 pm: |
^^^^i like that idea. i have a 8 ohm sub i got from james longo for christmas and i was thinking of building a little box to be hooked up to the home audio setup. |
Silver Member Username: Icecreamman5687
Post Number: 119 Registered: May-06
| Posted on Monday, January 08, 2007 - 03:00 pm: |
yah no bueno to try they are really expensive to get a converter...i went looking just to be able to power up amps to try and work on them... the cheapest is like 200 to have enought amps to keep the amplifier alive. other wise u will blow the fuses on the converter... |
Gold Member Username: N2audio
Lawrence,
Ks
Post Number: 1119 Registered: Mar-04
| Posted on Monday, January 08, 2007 - 04:55 pm: |
There's a 30A (32A surge) 13.8v power supply on ebay for less than $100. That would power the 300w amp - probably 400 or 500 if you don't blast it or try to play tones. Any bigger than that and you're better off just getting a home audio amp. |
