Thread: Can too many speakers burn out your H U |
Bronze Member Username: Basssquared
Post Number: 21 Registered: Nov-06
| Posted on Tuesday, January 02, 2007 - 02:45 pm: |
i have two 4.5" audiobahns on my dash two 6.5" in the front two doors and two more in the back doors and i wanted to put two more 6.5" speakers in the back underneath the rearwinshild will i burn out my head unit if i dont use an amp |
Relevant Product Info
Gold Member Username: Leew
XXXX!!WWWW,
Yokosuka, ...
YAKUDZA JAP...
Post Number: 1219 Registered: Jan-06
| Posted on Tuesday, January 02, 2007 - 08:34 pm: |
you have to use amp... my apm is 6ch plus one centre speaker amp and other amp drive 12" Alpine sub...so good... |
New member Username: Tkruger
Post Number: 2 Registered: Jan-07
| Posted on Wednesday, January 03, 2007 - 08:31 pm: |
Yes, to many speakers can fry your head unit. Most head units have a limited load of 4 ohms per channel. That means 1 speaker per channel. If you want to run multiple speakers you will need an amp. Look for an amp that is 2 ohm stable if you want to run 2 speakers per channel. I have 2, 2 channel amps that are each 2 ohm stable to power 8 speakers. |
