Thread: Choose between these amps |
Bronze Member Username: Kewinn89
Grand bay,
Alabama
Usa
Post Number: 56 Registered: Dec-06
| Posted on Monday, January 01, 2007 - 06:29 pm: |
i am going to purchase a amp in the upcomming days and these were some of my choices for my 2 12'' kenwoods! alpine,kicker,rockford fosgate,polk and jbl! can u tell me which one u prefer! |
Gold Member Username: Drsmith
Montana
Post Number: 2373 Registered: Nov-04
| Posted on Monday, January 01, 2007 - 06:39 pm: |
kicker and RF make good amps |
Gold Member Username: Alias747
Eclipse Ti,
MN
Post Number: 1827 Registered: Apr-05
| Posted on Monday, January 01, 2007 - 08:11 pm: |
Are those your only choices? Like you get large discounts on them or something? All of those brands for the most part are all pretty decent amps and will work for you just fine. You just need to find the one that will do the amount of power that you need with the features you need as well. |
Grand bay,
Alabama
Usa
Post Number: 59 Registered: Dec-06
| Posted on Monday, January 01, 2007 - 11:07 pm: |
well my 12'' kenwoods have these specs * 1000 Watts Peak * 200 RMS * frequency range 25-800 Hz * sensitivity 93 dB * silver pearl mica injection-molded polypropylene woofer cone * tornado-type raised ridge construction for improved rigidity and dampened response * urethane foam surround * Gold Connections * 63.4 OZ. Huge Magnet * Overlapping on cone surface gives improved frequency response * extended pole piece + bumped back plate allows increased cone excursion and performance * top mount depth: 5-5/16" * sealed box volume 1 cubic feet * ported box volume 1.5 cubic feet --Features, subs ^^ |
Grand bay,
Alabama
Usa
Post Number: 60 Registered: Dec-06
| Posted on Monday, January 01, 2007 - 11:21 pm: |
will someone help me pick out an amp for my subs please! |
Silver Member Username: Rtyauch301
Post Number: 107 Registered: Aug-06
| Posted on Monday, January 01, 2007 - 11:33 pm: |
whats the ohm raiting on those |
Post Number: 108 Registered: Aug-06
| Posted on Monday, January 01, 2007 - 11:37 pm: |
since kicker was one of ur choices this one will work if your ohm raiting is right http://cgi.ebay.com/BRAND-NEW-06-KICKER-ZX400-1-400-WATT-MONO-AMPLIFIER_W0QQitem Z180069301950QQihZ008QQcategoryZ79829QQrdZ1QQcmdZViewItem |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3821 Registered: Dec-05
| Posted on Friday, January 05, 2007 - 10:34 pm: |
PG xenon 400.1 from CTmike or matt dope |
Gold Member Username: Blainew
Alpine type S 6.5 inch...
Post Number: 2073 Registered: Nov-05
| Posted on Sunday, January 07, 2007 - 01:46 pm: |
kicker |
Bronze Member Username: Skibum12189
Post Number: 65 Registered: Mar-06
| Posted on Tuesday, January 09, 2007 - 12:00 am: |
kicker zx300.1 |
Silver Member Username: Qbenjamin
Florida
Post Number: 178 Registered: Nov-06
| Posted on Tuesday, January 09, 2007 - 03:11 pm: |
I hate it when a company lists crap like "oh 1000w peak but only 300w rms," You will never see that peak power. It's almost a rip-off for entry level car audio enthuiasts. |
Silver Member Username: Trey4sports
Post Number: 247 Registered: Sep-06
| Posted on Wednesday, January 10, 2007 - 09:47 pm: |
i recomend you get a JL 500/1 if your subs are 200 rms each because of the excellent build quality and the regulated power supply. not great for competition because it robs you of the benfits of a good electrical system and higher voltages, but excellent for daily driving because of the build quality |
