Thread: Hifonics and Kicker Help |
New member Username: Livingloudl7
Post Number: 4 Registered: Dec-06
| Posted on Thursday, December 28, 2006 - 07:37 pm: |
Ok I just got my new BXi 1606D Hifonics amp wired to a 2 ohm load to a 15" Kicker L7(dvc 4ohm). it basically runs pretty decent but if i turn the volume up all they way or at least close to it, the protect light comes on and the amp cuts off. and to turn it back on i have to restart my car or basically turn the amp off and back on. I'm not sure why this is going on.. but I know the Amp accepts 2-4 gauge wires and i have 8 gauge wires for the 12v and the ground? would this have anything to do with it? I don't have a cap or anything either just my stock electrical system on my 2k jeep grand cherokee. Any help would be GREATLY appreciated. |
Post Number: 6 Registered: Dec-06
| Posted on Friday, December 29, 2006 - 05:08 pm: |
Anyone? |
Gold Member Username: James1115
Use a simple...
Post Number: 8519 Registered: Dec-04
| Posted on Friday, December 29, 2006 - 05:23 pm: |
thats Hifonics for you. Check over all your wiring. |
Bronze Member Username: Shade
Moxee,
Wa
U.S.
Post Number: 48 Registered: Nov-06
| Posted on Friday, December 29, 2006 - 06:36 pm: |
i was under the impression the hifonics amps already detect what load to use by your sub wiring config. atleast that's how it worked for me |
Bronze Member Username: Derick06
Rio Grande City,
Texas
United States
Post Number: 53 Registered: Nov-05
| Posted on Friday, December 29, 2006 - 08:00 pm: |
You probably need 4 gauge wire for that amplifer. 1000 watts rms is too much for that 8 gauge wire. |
Silver Member Username: Brynm
Prince Albert,
SK
Post Number: 257 Registered: Jul-05
| Posted on Friday, December 29, 2006 - 11:36 pm: |
8 guage is way to small for that amp, you probably have some heavy voltage drop on that, upgrade it to 4 guage minimum preferably 2 guage. if you have access to a dc voltmeter put it on your power inputs of the amp with the music turned up it's probably not getting enough power |
Post Number: 7 Registered: Dec-06
| Posted on Saturday, December 30, 2006 - 12:04 am: |
Yeah thats probably best.. I'll get 2 or 4 gauge wires and let you know how it goes. |
Bronze Member Username: Imalik
Jackson,
New Jersey
Ocean
Post Number: 41 Registered: May-06
| Posted on Sunday, December 31, 2006 - 04:58 pm: |
you need 1/0 gauge wire for that amp, that could be the reason why its going into protect mode, check your speaker, make sure it's wired right. when set up right that amp will do a very good job |
Use a simple...
Post Number: 8585 Registered: Dec-04
| Posted on Sunday, December 31, 2006 - 05:08 pm: |
its not the wire, I would check all your wiring, in the box, from the box to the amp make sure it is wired correctly. Check and make sure the ground is solid and the paint is scratched away and it is secure. make sure there is no strands of wire arcing the neg and pos terminals all it takes is one strand. I would bet on wiring problem not size of wire. http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=1&woofer_imp=4 |
Post Number: 8 Registered: Dec-06
| Posted on Tuesday, January 02, 2007 - 01:31 am: |
Well I'm pretty sure my wires are all secure. But do you think its safe to run 8 gauge wires with 1100 wrms? also would a cap. help maybe? |
Gold Member Username: Ctmike
Ct.
Post Number: 2860 Registered: Feb-06
| Posted on Tuesday, January 02, 2007 - 01:35 am: |
i'd up it to 4 gauge at least and no a cap. wont help. |
Jackson,
New Jersey
Ocean
Post Number: 45 Registered: May-06
| Posted on Tuesday, January 02, 2007 - 12:38 pm: |
If you look in the manual you will see that amp req's 1/0 gauge wire. I have a 1206d |
Post Number: 9 Registered: Dec-06
| Posted on Tuesday, January 02, 2007 - 08:33 pm: |
Ok so its not going to help my problem but a cap would help my system overall. I bought my amp on ebay so I didn't get a manual but thanks Malik. |
Use a simple...
Post Number: 8635 Registered: Dec-04
| Posted on Tuesday, January 02, 2007 - 11:52 pm: |
your lucky if you get 1000 watts out of that amp, I repeat LUCKY! your wiring could be upgraded to 4 guage but again its not your wiring thats your problem. Try changing your ground. Also maybe you bought a faulty amp. |
Post Number: 10 Registered: Dec-06
| Posted on Thursday, January 04, 2007 - 06:31 pm: |
How many watts do you think it truely puts out at 2 ohms? 1 ohm? I also purchased bigger wire and i'll install it later this week. Also I turned the gain down very slightly and the problem ceased. It barley affects the volume too. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3817 Registered: Dec-05
| Posted on Friday, January 05, 2007 - 10:19 pm: |
BIG 3+ HO alt |
Use a simple...
Post Number: 8645 Registered: Dec-04
| Posted on Friday, January 05, 2007 - 10:50 pm: |
60% power is what to expect out of that amp. |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 2048 Registered: Jul-06
| Posted on Friday, January 05, 2007 - 11:38 pm: |
ive heard 80% for hifonics amps, im hoping its 80% and not 60% cause i got my 1206d chillin here next to me. rated at 1200 at 1 ohm, hoping to get atleast 900-1000 out of it. and just for kicks, id upgrade the 8 gauge to something bigger, 1/0 preferably cause incase you upgrade later |
Platinum Member Username: Rovin
1 12 Premier...
Post Number: 10328 Registered: Jul-05
| Posted on Friday, January 05, 2007 - 11:59 pm: |
im thinking he's got a current draw issue - not enough juice being created fast enough still try upgrading that punny wire though..... |
Post Number: 3824 Registered: Dec-05
| Posted on Saturday, January 06, 2007 - 11:38 am: |
james put 60% cuz of voltage drops. But you can expect 1000w rms from that hifonics if you have a good electrical system. |
Bronze Member Username: Livingloudl7
Post Number: 11 Registered: Dec-06
| Posted on Sunday, January 07, 2007 - 09:39 pm: |
And again thats 1000wrms at 2 ohms? so it would be 80% of its rated 1600 wrms at 1 ohm correct? |
Post Number: 3846 Registered: Dec-05
| Posted on Monday, January 08, 2007 - 09:40 am: |
i'd only use that amp at 1 ohm personally. |
Silver Member Username: Icecreamman5687
Post Number: 117 Registered: May-06
| Posted on Monday, January 08, 2007 - 02:53 pm: |
be carefull at running that amp at one ohm.. have a good electrical system to back it cause i have the bxi1606d ran at 1 ohm and it messed my amp up bad.. all that happens now is that the power light blinks and it constently sends a short pulse to my subs when the light blinks even with the hu turned down...i called the people at hifoniks and they said it sounds like i starved the amp to death.... |
Post Number: 12 Registered: Dec-06
| Posted on Monday, January 08, 2007 - 04:21 pm: |
Well I guess I'll upgrade the elec. system. but why would you only want to run it at 1 ohm? wouldn't it run more effecient at 2 ohms? |
