Thread: Rockford Fosgate P6001bD with Kicker 12" CompCVRs |
New member Username: Jgelp7
Post Number: 2 Registered: Dec-06
| Posted on Monday, December 25, 2006 - 08:58 pm: |
Would a Rockford Fosgate P6001bD work well with 2 Kicker 12" CompVRs at 2ohms? I'm new to subs and amps and need a little help. The amp is Rockford Fosgate P6001bD -- (Chrome Amp) MonoBlock Punch Series Class BD Amplifier and is 600w RMS x1@2 ohms. The subs are 600w RMS 2ohm as well. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3784 Registered: Dec-05
| Posted on Monday, December 25, 2006 - 09:26 pm: |
i suppose you got the dual 2 ohm version of those subs. I'd get a kicker zx 750.1 because the price is almost the same, you can get more output and the quality is the same if not supérior. Try that. |
Post Number: 3 Registered: Dec-06
| Posted on Monday, December 25, 2006 - 10:08 pm: |
I was looking for something under $300. The Rockford Fosgate I had in mind was $200, and the Kicker 750 was around $500. Are there any suggestions for an amp under 300 that can power these subs? |
Post Number: 3786 Registered: Dec-05
| Posted on Tuesday, December 26, 2006 - 10:58 am: |
is ebay an option?? i'll show you a better deal |
Post Number: 5 Registered: Dec-06
| Posted on Tuesday, December 26, 2006 - 05:28 pm: |
yea sure, ebay is fine. |
Post Number: 3791 Registered: Dec-05
| Posted on Tuesday, December 26, 2006 - 05:53 pm: |
http://cgi.ebay.com/NEW-06-Kicker-Mono-Amplifier-ZX750-1-Car-Audio-Amp-750_W0QQi temZ110071994404QQihZ001QQcategoryZ79829QQrdZ1QQcmdZViewItem there's an auction or check this with 1 year warranty http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16918 |
Post Number: 6 Registered: Dec-06
| Posted on Tuesday, December 26, 2006 - 06:23 pm: |
Ok thanks for the help, I'll pick up the Kicker zx750 off ebay. |
Post Number: 7 Registered: Dec-06
| Posted on Tuesday, December 26, 2006 - 10:33 pm: |
would it be better for me to buy the 2 12" Kicker CVR's already in the kicker enclosure for $250 or to buy the subs off ebay for $95: http://cgi.ebay.com/2-KICKER-CVR12-CompVR-12-Car-Subwoofers-PAIR-05CVR122_W0QQit emZ300063598546QQihZ020QQcategoryZ39777QQrdZ1QQcmdZViewItem and then buy a sealed enclosure seperate for arpund $40? Then could I just bring them to a place to get wired up and installed or do I need to buy wiring and wire them up in the enclosure myself? How much should installation cost, and is it worth it to buy the subs and box and wiring seperate or to just buy a wired Kicker box with the 12" CVR's in it already from sonic electronix for $250? |
Post Number: 3795 Registered: Dec-05
| Posted on Wednesday, December 27, 2006 - 01:09 pm: |
that's your choice. I'd personally buy them alone and do a ported box by myself but... it's your choice. |
Post Number: 10 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 02:49 pm: |
Would it make a difference? I'm looking for simplicity. I want to buy the subs, amp, and box and then just bring it all down to a place to get hooked up. I don't have the knowledge of car audio to install them myselves. I think I will be getting the zx750.1 you suggested from ebay and these subs: http://www.sonicelectronix.com/item_3867.html Then can I just bring them down to get installed? |
Bronze Member Username: Jgelp7
Post Number: 12 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 06:55 pm: |
Will the Kicker zx750.1 give the 2 CVRs 750w RMS to both or will it be split in two and give them 375 each? |
Post Number: 3798 Registered: Dec-05
| Posted on Wednesday, December 27, 2006 - 10:12 pm: |
the amp is underrated and they will see between 400-450. if you want simplicity then get the package from sonicelectronix and remember to order the dual 2 ohm version of those subs |
Post Number: 18 Registered: Dec-06
| Posted on Wednesday, December 27, 2006 - 10:16 pm: |
Ok thanks. So will 400-450 going to that package be decent? And do you have any estimate on how much installation should cost me? |
Post Number: 21 Registered: Dec-06
| Posted on Thursday, December 28, 2006 - 05:16 pm: |
So how will this set up compare to 2 10" JL W3's? Thats what one of my friends has. Is installation usually expensive? |
Post Number: 3806 Registered: Dec-05
| Posted on Friday, December 29, 2006 - 09:28 am: |
Bro i'm not in US territory so i can't really tell you how much you should pay. Those subs will beat those w3 if they're in the right box. They will not sound better but louder. |
New member Username: Sheriff
Post Number: 2 Registered: Jan-07
| Posted on Monday, January 08, 2007 - 06:26 pm: |
Installation for my amp and subs was $60 after I purchased a amp wiring kit for $30. The most you will probably pay for installation is about $120. |
