Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Installing Jensen VM9311TS Problem, p...
Author Thread: Installing Jensen VM9311TS Problem, please help!
Username: Snowboardbum
Post Number: 18
I have everything hooked up, and the unit turned on just fine. Radio works, but when I put in a DVD it said bad disc, so I then pressed the eject button, and it sounded like the disc was spinning and jammed. The disc won't come out. Is this just a bad unit?! Or is there something to it?
Home > Message Board > Car Audio > Multimedia Systems > Archive through February 06, 2007 > Installing Jensen VM9311TS Problem, p... [ « Previous ] [ Next » ]
