Thread: Head Unit fuse |
Bronze Member Username: Kiltface
Post Number: 12 Registered: Apr-06
| Posted on Sunday, December 24, 2006 - 11:26 am: |
My sisters fuse on her head unit blew so i replaced it with another one. The fuse i took out was 5A but i only had a 30A to replace it with. Will this be a problem or does it not matter? |
Silver Member Username: Jaackdeth
United States
Post Number: 728 Registered: Sep-04
| Posted on Sunday, December 24, 2006 - 07:21 pm: |
It could be a problem yes, you could burn something out. I would put as close to 5 as you can to prevent damage. |
Post Number: 13 Registered: Apr-06
| Posted on Monday, December 25, 2006 - 12:08 pm: |
i tried a 15A in it but it didnt seem to work but with the 30 it was fine. Should i try to get another 5A and see if it works? |
United States
Post Number: 731 Registered: Sep-04
| Posted on Monday, December 25, 2006 - 12:15 pm: |
Are you saying that there was a 5 amp in there, and now you put in a 15 and that doesn't work? If so there is a problem, as another 5 should work. |
Post Number: 14 Registered: Apr-06
| Posted on Tuesday, December 26, 2006 - 07:47 am: |
This is what happened. My sister had to get a new battery for her car and when it was taken out the cd player stopped working, there was no power and not even the security light flashed. So i took it out and thought to check the fuse, i took out the 5A that was in there and replaced it with a 15A as this was the closest i had to it but it didnt work so i put in a 30A and it worked again. I cant understand why this happend. Thanks for you help |
