Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Wiring help
Author Thread: Wiring help
Username: Homegrowncam
Funky Town, TX
United States
Post Number: 338
Alright so I have an Alpine 9856. I installed it myself last January. When I installed it I hooked up all the wires with electrical tape. Well 2 nights ago I was at a buddys house and he had a set of Inifinity 6.1s laying around that we decieded to install. Doing so we switched RCAs in the baack of the head and the electircal tape slipped off and wires were exposed. The head unit wouldnt turn on so I just put it all back and decided to work on it this morning. My thing is I have checked wires and made sure all are connected accordingly and connected them with those wire connectors where you slide the stripped wires in and then twist the cap. Now it still isnt turning on and I was wanting to know what to look for? ANy help at all is apreciated.
Username: Tjmutlow
Post Number: 3383
need to see if your getting power at the constant and switched wires, use a test light, or see if you blew the fuse in the fuse panel.
Funky Town, TX
United States
Post Number: 340
So i am not getting power from my power wire and no fuses are blown.
Username: Tjmutlow
Post Number: 3394
fuse cannstill be blown and not able to be seen, you really need a test light or something to test them, they should have power on 2 sides of the fuse.
Username: Tjmutlow
Post Number: 3395
or you have another fuse box under the hood
Funky Town, TX
United States
Post Number: 341
i checked the fuse box under the hood and all the same.
Username: Leew
XXXX!!WWWW, Yokosuka, ...
YAKUDZA JAP...
Post Number: 1143
Cameron
if your car is Nissan Altima 1997,then could be this sh!t:
somehow you connected ACC wire to the RR (+) speaker,cause it's the same color,also +12 is the same color as LR (+) speaker!!! So, check this out:
Check all connections with DMM or a light bulb
Username: Smrts82
I need help finding a power source for a dvd player and 2 monitors in a 2004 suburban. I plan on leaving the factory stereo alone. Can someone help please?
Username: King33
Post Number: 18
You probably otta start a new thread under a different toppic or you may not get any help.... I dont know anything about it.
Funky Town, TX
United States
Post Number: 342
no i onnected the powering right becuase i have a separate amp powering my speakers. the power is conected properly just not getting anything from it.
Username: Swampthang
i need a wireing diagram or the color code for a 1989 f150 the previous owner cut up the wireing harness for the radio so i need to know what wire gose where
thanks
jason
Funky Town, TX
United States
Post Number: 344
bump
Funky Town, TX
United States
Post Number: 356
any other suggestion. before i knew my power wire coming off the harness had power because i would touch it to my anntenna wire and teh antenna would rise but now it does nothing.
Username: Tjmutlow
Post Number: 3411
did you use a test light on all the fuses, it really sounds like a fuse issue, due to the switched power is not working
Funky Town, TX
United States
Post Number: 366
i started a new thread about it
http://forum.ecoustics.com/bbs/messages/4/306771.html
Funky Town, TX
United States
Post Number: 369
anybody? its lonely without a radio.
Username: Arande2
400dB could probably d..., 4000 isnt ev...
100,000dB FU...
Post Number: 384
Agh I know the feeling. I wouldn't know though.
Username: Billfl1
Good afternoon!!! can anyone tell me how to obtain a wiring diagram for a 2000 ford windstar LX. I'm trying to install an after market radio. tks..
Username: Foodlion01
i need a wiring diagram fo a 1990 blazer 1500 for a durabrand cd player
Username: Strandman
Carlsbad, Ca
Us
i need the radio wiring color codes for a 1989 ford clubwagon. please help!
Home > Message Board > Car Audio > Head Units > Archive through March 13, 2007 > Wiring help [ « Previous ] [ Next » ]
