Thread: THD % Rating |
Silver Member Username: Devastation101
Audioque SD2.5-ville,
HENDERSON, NC
US of A
Post Number: 559 Registered: Feb-06
| Posted on Saturday, December 16, 2006 - 11:25 am: |
How can you determine a good THD rating? Plus, are these features good: PerformanceFrequency Response 10 Hz - 320 Hz Signal to Noise Ratio 90 dB THD at Rated RMS Power 0.1 %Crossover / Equalizer Bass Boost With Bass Boost Bass Boost Frequency 50 Hz Low - Pass Frequency 32 Hz - 320 Hz |
Gold Member Username: James1115
Use a simple...
Post Number: 8121 Registered: Dec-04
| Posted on Saturday, December 16, 2006 - 12:03 pm: |
for a class D amp that is fine. On anything under 80hz you typically can't hear distortion under abour 10% When it comes to class a/b 10% would be AWFULL!! |
Silver Member Username: Dsmith07
LaGrange,
NC
US oF A
Post Number: 320 Registered: Jun-06
| Posted on Saturday, December 16, 2006 - 12:07 pm: |
Rated Power:500 W RMS @ 1.5 ohm - 4 ohm 11V-14.5V) THD at Rated Power:0.05% @ 4 ohm S/N Ratio:>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth) Frequency Response: 5 Hz - 500 Hz (+0, -1dB) Damping Factor: >500 @ 4 ohm / 50 Hz >250 @ 2 ohm / 50 Hz Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS are those good specs on my amp? |
Use a simple...
Post Number: 8122 Registered: Dec-04
| Posted on Saturday, December 16, 2006 - 12:08 pm: |
Use a simple...
Post Number: 8123 Registered: Dec-04
| Posted on Saturday, December 16, 2006 - 12:33 pm: |
is that a 500/1 ? |
LaGrange,
NC
US oF A
Post Number: 323 Registered: Jun-06
| Posted on Saturday, December 16, 2006 - 02:08 pm: |
yep  |
Use a simple...
Post Number: 8124 Registered: Dec-04
| Posted on Saturday, December 16, 2006 - 04:22 pm: |
nice amp |
Use a simple...
Post Number: 8138 Registered: Dec-04
| Posted on Saturday, December 16, 2006 - 08:24 pm: |
bump |
LaGrange,
NC
US oF A
Post Number: 331 Registered: Jun-06
| Posted on Saturday, December 16, 2006 - 10:18 pm: |
i wouldnt know if its nice or not yet cuz its on layaway but i will have it off around x mas time im just so ready to get it ...powering a Diamond d6 12  |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3745 Registered: Dec-05
| Posted on Sunday, December 17, 2006 - 10:18 am: |
with amps the deal is so easy. You look some specs, brand, ohms and you're done. But with subs, damn you need to hear them, listen to reviews, get mad with other people because they bump or not hehe, too many factors. |
Use a simple...
Post Number: 8153 Registered: Dec-04
| Posted on Sunday, December 17, 2006 - 12:53 pm: |
yup |
