Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > A little help with ohms....
Author Thread: A little help with ohms....
Username: Jryan23
alright if i wanted to get a dual 2 ohm sub that needed to be powered by two mono amps, in what way would i want to hook up the sub and what ohm stable should the amps be.
can someone please explain how all this sh!t works
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4560
www.the12volt.com -- then go to wofer wiring.
if you still need help, we'll be glad to help you
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4562
bump
Username: James1115
Use a simple...
Post Number: 8125
you want a single dual voicecoil sub and 2 amps to run it? may I ask why? I would run it mono parellel/parellel to 1 ohm on one amp. another good site besides 12volt is www.bcae1.com
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > A little help with ohms.... [ « Previous ] [ Next » ]
