Thread: What amps should I gut to push 4 15" L7's? |
New member Username: Bipolarjoe
Post Number: 2 Registered: Dec-06
| Posted on Friday, December 15, 2006 - 10:35 pm: |
And what ohm subs should I get? CRX install.. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3727 Registered: Dec-05
| Posted on Friday, December 15, 2006 - 10:41 pm: |
well, if i were you i would do two 2000w rms amp. If you want to go the easy way then grab 4 dual 2 ohm subs and wire them to a big 4000w rms amp at 1 ohm. Try grabbing an adassa warlord from stevemeade forum. That should sound pretty loud |
Post Number: 3 Registered: Dec-06
| Posted on Friday, December 15, 2006 - 11:37 pm: |
How would I wire that up to the single amp? |
Post Number: 3731 Registered: Dec-05
| Posted on Saturday, December 16, 2006 - 10:04 am: |
www.the12volt.com hit the link woofer wiring |
Post Number: 4 Registered: Dec-06
| Posted on Saturday, December 16, 2006 - 01:26 pm: |
Thanks man. I added that site to my fav's.. |
Post Number: 5 Registered: Dec-06
| Posted on Saturday, December 16, 2006 - 01:28 pm: |
If I got 4 subs rated at 2000 rms im going to need more then 4000 watts though...Man those L7's really hold that much power?? wow |
Post Number: 6 Registered: Dec-06
| Posted on Saturday, December 16, 2006 - 01:30 pm: |
sorry..scratch that... 1000 watts rma..2000 maxx so 4000 is perfect |
Post Number: 3746 Registered: Dec-05
| Posted on Sunday, December 17, 2006 - 10:21 am: |
bipolar joe... L7s are 1000w rms, just look rms. 4x1000w rms subs= 4000w rms amp. |
