Thread: Effective Dual DVD Bypass Codes (w/ NO SWITCH) |
Bronze Member Username: Eric985
Post Number: 24 Registered: Nov-06
| Posted on Friday, December 15, 2006 - 12:59 pm: |
I've researched many ways of bypassing the brake safety of Dual DVD systems, with the help of others in the "Bypassing parking brake feature" thread. For the ease of all new users, I decided to compile this list of the three easiest and most effective methods. These methods have worked on a variety of Dual DVD systems (mainly XDVD8181, also XDVD710), unsuprisingly, since Dual stated to me that most installations have the same codes. WARNING! It is usually ILLEGAL and most of all UNSAFE to drive while watching video. I only watch video while parked, and I suggest you do the same. This is for demonstration purposes only, if you use these codes, you do so at your own risk. STEP ONE. Ground the E-Brake wire. No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground). 1. FACTORY RESET METHOD (Temporary) (This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.) ** Go to the Menu ** Get to the Settings Menu ** Select <yes> to Reset to Factory Settings. Credit: DKA Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost. ---------------- 2. AUDIO CD METHOD (Permanent) ** Insert Audio CD ** Press PLAY ** Press STOP twice on remote ** Enter 26604 on remote ** Press ENTER ** Take out Audio CD and Insert a DVD Credit: Myself via a DUAL Tech ---------------- 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Credit: Adam P. The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution. |
Post Number: 25 Registered: Nov-06
| Posted on Friday, December 15, 2006 - 01:01 pm: |
Each of these methods have worked for several different Dual users. I'm not saying they will definitely work on yours, but these seem to be the most effective solutions (aside from those requiring switches). Good luck and enjoy! |
Post Number: 26 Registered: Nov-06
| Posted on Friday, December 15, 2006 - 01:03 pm: |
Method 3 worked for my XDVD8181. |
New member Username: Lanefa
New Bern,
NC
Post Number: 1 Registered: Dec-06
| Posted on Saturday, December 16, 2006 - 06:30 pm: |
3 worked, but when i turn my headlights on I get a "signal not detected" screen. Any ideas? |
New member Username: Awp
Post Number: 2 Registered: Dec-06
| Posted on Wednesday, December 20, 2006 - 02:28 am: |
Yes, you have the "Reverse Light" detection wire hooked to the illumination wire for the Instrumant lamps and it's triggering your Back-up Camera" input everytime you turn on the parking/headlamps. Pull the radio and unhook the Reverse Light sensor wire from your factory harness connection (I think it's a brown with a white tracer wire, look in he wiring diagram in the book to be certain and you probably have it hooked to one of the orange wires from the harness kit.)and just tape the ends over as it is not needed unless you will be using a backup camera. |
New member Username: Peaty
| Posted on Tuesday, December 26, 2006 - 07:01 pm: |
Just got done installing mine. I'm happy to say the third DVD method worked for me. I hooked up the yellow parking brake wire to a permanent ground and tested it before I installed it. Worked like a charm. I can't thank you enough. Nice work. |
New member Username: Devilstoy
Jersey
Post Number: 2 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 09:47 pm: |
do i need to do this with a cd and then again with the dvd or does just the dvd method # 3 work ? thanks |
| Posted on Tuesday, January 02, 2007 - 10:20 pm: |
Your post reminded me that I needed to do this again since I worked on my car this weekend and had to remove the fuse panel. I forgot because it kept my stations I just this minute did it again and for me Method worked fine. I did have to try it twice but I think that was because I may have entered the numbers in wrong. No matter it worked  |
Jersey
Post Number: 3 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 10:26 pm: |
method 3 ? |
Jersey
Post Number: 4 Registered: Jan-07
| Posted on Tuesday, January 02, 2007 - 10:27 pm: |
is that supposed to method 3 ? im doing mine tomorrow and want to make sure i do it right the first time lol |
Post Number: 3 Registered: Dec-06
| Posted on Tuesday, January 02, 2007 - 11:24 pm: |
Gaah yes method three sorry I thought I typed that. |
New member Username: Djnicoya
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 04, 2007 - 03:13 am: |
Can someone please tetll me how to ground an e-Brake? I have never done this and am not sure what im doing. i have the DUAL 8181 and just had it installed but I want to by pass the dvd security, but im not sure how to ground the wire. |
Post Number: 4 Registered: Dec-06
| Posted on Sunday, March 04, 2007 - 09:19 am: |
The yellow wire marked "Parking" needs to be attached to a ground. You can just attach it to the black wire from the speaker harness on the head unit. |
Post Number: 2 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 03:36 pm: |
What could I be doing wrong. I grounded the ebrake wire ( cut it, striped off an end and grounded it against a screw per instructinos from an uncle cuz i didnt know how to ground a wire). I then turned on the car, played the dvd and hit stop twice and entered code and nothing, i also tried the other 2 methods, any advice as to what im doing wrong? or what else i could try? |
Post Number: 5 Registered: Dec-06
| Posted on Monday, March 05, 2007 - 04:00 pm: |
When you say e-brake wire do you mean the yellow one or the blue one? Just double checking. First thing I'd do is try another ground or verify continuity to ground at the screw you used for the ground. |
Post Number: 3 Registered: Mar-07
| Posted on Monday, March 05, 2007 - 04:09 pm: |
I used the yellow one. it also happens to have a green stripe. Also incase it makes a difference, My DUAL is an 8181 and it requires me to do a procedure with the parking brake to let it go, lift it, let it go and then lift it again in order to activate the screen, does that make a difference? |
Post Number: 6 Registered: Dec-06
| Posted on Tuesday, March 06, 2007 - 12:35 am: |
Yes the yellow with the green stripe, your system sounds just like mine. I just connected the wire to the mount the stereo goes in, for me it's also where the stereo itself has a ground. Not sure this will help at all but I have my install here: http://www.scoobymods.com/forums/showthread.php?t=7238 You need to register to see the pics but it's free to do so. It did take me a couple of tries to get it to work. double check your ground too. |
Post Number: 4 Registered: Mar-07
| Posted on Wednesday, March 07, 2007 - 05:39 pm: |
Thanks for the help Pete. I finally got it to work, i just wasnt using a good enough ground and im a novice at this so i didnt wanna try to pull out the deck, but i found my way around pulled it out and grounded it to the harness. Thanks again |
New member Username: Malicious01
| Posted on Thursday, March 08, 2007 - 01:01 am: |
does anyone know if anyy of the methods work on xdvd8265??? i see alot of people have success with 8181 but has anyone had success with 8265 or is my model gyro? |
New member Username: Rayboogy01
| Posted on Sunday, March 11, 2007 - 08:50 pm: |
Hey guys this is a great forum. I just had a dual xdvd8182 installed in my girlfriends car. I tried the bypass code method but it doesn't work. Does anyone know if there is a different code for this model or am I just doing it wrong? She has a Mitsubishi Lancer ES. I know it was a pain to ground it outside of the parking break. But the guy that I had install it spliced the antenna on the car. Any help will greatly be appreciated. Thanx. |
Oklahoma City,
OK
U Essay
| Posted on Thursday, March 15, 2007 - 07:55 am: |
What if you don't have a remote?? |
New member Username: Tacoman2006
Post Number: 1 Registered: Apr-07
| Posted on Monday, April 02, 2007 - 10:36 am: |
question (alot off topic) the sudwoofer wire is mono? i have two lead going to my amp but if i connect it to the rear out from the player i cannot control the amp/sub how do i fix this do i "y" the mono sub pre-out? or what--- PLEASE HELP! |
New member Username: Solo67042
| Posted on Sunday, April 08, 2007 - 12:50 pm: |
i just recently had a 8181 installed in my 05 monte carlo, i cannot get any of the codes to work for me. i had it installed at bestbuy, is it possible they did sonething so that i could not bypass the unit? any input would be great thanks |
New Bern,
NC
| Posted on Sunday, April 08, 2007 - 06:19 pm: |
They connected the parking brake wire, which means that the code will not work! I recently went through this with my neighbor. After two weeks of arguing, he unhooked the wire, and, OMG, the code worked. |
Post Number: 2 Registered: Apr-07
| Posted on Monday, April 09, 2007 - 12:10 am: |
ok so i need to disconnect what wire??? i assum it would be the one running towards my parking brake but what color should it be just in case? |
Post Number: 3 Registered: Apr-07
| Posted on Monday, April 09, 2007 - 10:18 am: |
i found the wire leading to my parking brake, its yellow with a stripe of blue but i dont understand how unhooking it will make the code work. unhooking it would be like leaving it there since there is no ground, isnt that right? anyways thanks adam i just need more info |
Post Number: 5 Registered: Apr-07
| Posted on Tuesday, April 10, 2007 - 11:59 am: |
ok, well i unhooked the wire and grounded it to a bolt on the firewall, i am still getting the same result. since best buy installed the unit i cannot get the unit out to slice the wire into the ground. i can see under my dash the harness that was used and there is a black wire running out of that. is that a ground as well? sould i just use a splice connector to connect the 2 wires? |
New member Username: Ghthree3
Thomasville,
Ga
Usa
| Posted on Saturday, April 14, 2007 - 10:26 pm: |
i tried the three step process for the dual tv ,it worked great |
New member Username: Msnell901
Post Number: 2 Registered: Jun-07
| Posted on Wednesday, June 20, 2007 - 08:39 pm: |
dvd option work with 8181!!! great post! TY! |
New member Username: Codylornace
Texarkana,
Tx
U.S.
Post Number: 1 Registered: Jun-07
| Posted on Monday, June 25, 2007 - 10:55 pm: |
my xdvd8181 wont load a cd...i put it in and i hear it spinning and it says loading but then it follows with eject and out comes the cd...i need some help guys its really aggravating..please email me with any tips...codylorance@gmail.com...thanks alot |
New member Username: Dancear99
| Posted on Friday, June 29, 2007 - 12:24 pm: |
I need help too . I have my Dual in dash xdvd710 hooked up to my amp and subs. Every function (cd, dvds, radio, and aux) all play through my system but now my ipod wont. It plays but only through the my car speakers but will not play through my subs. Everything was working fine with the ipod until i hooked up the ps2 to the aux. Do you think that might have something to do with it or do you think a connection has came loose? Sorry for posting in so many areas, just trying to get this solved. If any one has any info about this can you please email me: Dancear@tmail.com Thanks |
New member Username: Fadizzle03
Jackson,
Michigan
Post Number: 5 Registered: Jul-07
| Posted on Thursday, July 05, 2007 - 04:27 pm: |
CAN YOU PLEASE TELL ME IF THIS WORKS WITH THE XDVD8183? DO I NEED TO HAVE THE WIRE GROUNDED? I WOULD APPRECITE THE HELP |
New member Username: Troubleis
| Posted on Saturday, July 14, 2007 - 05:25 pm: |
Dual 8265 DVD code worked, make sure you are using the main remote when entering the code. |
Post Number: 3 Registered: Jun-07
| Posted on Saturday, July 14, 2007 - 05:26 pm: |
^^^^^^^ Should be dual 8285 |
New member Username: Andersonoscar5
Post Number: 6 Registered: Jul-07
| Posted on Saturday, July 21, 2007 - 06:51 am: |
quote Each of these methods have worked for several different Dual users. I'm not saying they will definitely work on yours, but these seem to be the most effective solutions (aside from those requiring switches). Good luck and enjoy! Easy-to-use and high speed All-in-One DVD creator and DVD burner. It can converts ALL formats of video files directly to DVD disk, including DivX, Xvid, AVI, MPEG, WMV, QuickTime, Real Video format, etc. http://www.hotdvdtools.com/ |
New member Username: Esim1983
New Iberia,
Louisiana
U.S.
Post Number: 5 Registered: Jun-07
| Posted on Friday, July 27, 2007 - 04:40 am: |
I have an indash Ford F-150 navigation, it is a 2007 audiophile does anyone know how to get it to play Dvd's? Also do you know how to get the bluetooth feature working for my cell phone and the unit? I have tried to press the mute button twice, but nothing happened! Thank you Elliot |
New member Username: 1fierce1
Post Number: 1 Registered: Sep-07
| Posted on Tuesday, September 04, 2007 - 01:37 pm: |
Please help. I need the bypass code and proceedure for a Pioneer AVHP4900DVD. |
New member Username: J0schm03
| Posted on Sunday, September 09, 2007 - 06:08 pm: |
I'm wondering also if this works for the 8183. Cause I'm about to get mine sent to my place. Had two 8181 units break on me under warranty so they said they are sending me the brand new model :D Thanks if anyone knows if this works. |
New member Username: Cspiringer
Post Number: 1 Registered: Oct-07
| Posted on Friday, October 19, 2007 - 11:11 am: |
Does any one know how to bypass the parking break on a dual xdvd8182 i tried the codes they did not work |
New member Username: Grsteffes
DEL VALLE,
TX
| Posted on Saturday, October 20, 2007 - 01:53 pm: |
DOES ANYONE HAVE IDEAS FOR THE OVERIDE CODE FOR THE MITSUBISHI MULTI-COMMUNICATION SYSTEM I WOULD LIKE TO OVERRIDE THE DVD SO IT WILL PLAY IN DRIVE FOR THE BACK INSTALLED SCREENS |
New member Username: Francis_ohara
| Posted on Sunday, October 21, 2007 - 09:03 pm: |
Okay, I am new to installing a car stereo. I put a JVC KD-NX5000 in a 2000 BMW Z3 Roadster. Please explain how to bypass the DVD block so it will work with parking brake off. Thanks in advance for the help. |
New member Username: Soloshy
Post Number: 1 Registered: Nov-07
| Posted on Tuesday, November 06, 2007 - 12:16 am: |
I have a dual 8181 and I just hooked it up and I hooked it up just how it said in the book. but I dont think im hooking sum thing up right cause I keep geting that screen to pull the parking brake to watch the video. What do I do, do I not hook that yellow and blue wire just ground it to metal and do step number three. help me out please}}}} |
New member Username: Fordguy07
Marlow,
OK
| Posted on Saturday, November 10, 2007 - 06:16 pm: |
how do i bypass the brake after the wire is grounder on Dual XDVD700 |
New member Username: Timowen1
Tipp City,
Ohio
| Posted on Tuesday, November 20, 2007 - 10:43 pm: |
method 3 worked for my XDVD8183 |
Tipp City,
Ohio
Post Number: 2 Registered: Nov-07
| Posted on Tuesday, November 20, 2007 - 10:49 pm: |
does anyone know if it is possible to make the time of day default on start up instead of current radio station on the Dual XDVD8183 maybe using a set up change simular to the brake wire bypass. |
New member Username: 06dodge20
Shawsville,
Virginia
Mongomery
| Posted on Wednesday, November 28, 2007 - 05:40 am: |
I have a Dual 8181, I am wanting to hook up my Playstation 2 to it. How do I do this? Also How long does it take for the screen saver to come on? It says its on but It has never came on. Thanks |
New member Username: Bzbatl
Post Number: 1 Registered: Dec-07
| Posted on Saturday, December 15, 2007 - 01:00 am: |
Method 3 worked for me on a Dual XDVD8183 purchased from Best Buy. Thanks! Any ideas if there's a firmware upgrade for this DVD player to allow DivX? |
New member Username: Sp0rt4320
Cirtus Springs,
FL
US
| Posted on Thursday, December 27, 2007 - 11:15 pm: |
What is with the Dual8181 screen saver...It has an on/off switch but what is it. |
New member Username: Cyberalexander
Post Number: 2 Registered: Jan-08
| Posted on Wednesday, January 16, 2008 - 10:39 pm: |
Hello, I have a Dual xdvd8285 applies the code for parking bypass, but now when placing the screen in stanby, it is placed in black only about 5 seconds and then reappears video, it is not applied according to the Standby screen, I do? Has something to do bypass brake by code? Thanks. |
New member Username: Albundy0808
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 20, 2008 - 11:28 pm: |
how do you ground the e brake wire? |
Tipp City,
Ohio
Post Number: 5 Registered: Nov-07
| Posted on Monday, January 21, 2008 - 07:06 am: |
alex goodwin you did not say what head unit you have. I have the Dual XDVD 8183 and I have used the bypass code and bypassed the e-brake set up all together and grounded my e-brake wire at the same place and along with my head unit ground wire. |
Post Number: 3 Registered: Jan-08
| Posted on Monday, January 21, 2008 - 03:17 pm: |
i have a dual xdvd 8182 |
New member Username: Bfraser9655
Arlington,
Massachusetts
| Posted on Tuesday, January 22, 2008 - 04:54 am: |
just got xdvd8183.. tried all three codes.. none worked.. any ideas on what to do? |
Tipp City,
Ohio
Post Number: 6 Registered: Nov-07
| Posted on Tuesday, January 22, 2008 - 06:53 am: |
Brenden Fraser, take your time and try no. 3 again. Make sure you follow the directions exactly as printed. I can't believe it don't work. Is the yellow ground wire hook up right? I connected my yellow ground and the black head unit ground wire together and connected them to the radio harness ground. That way the are getting the original radio chassis ground that was factory installed when the head unit wiring harness is plugged into the factory harness. What type of vehicle are you working with? |
Arlington,
Massachusetts
| Posted on Thursday, January 24, 2008 - 02:33 am: |
its a 2004 taurus. i figured out what went wrong, the ground wire came loose from its connector while i was putting my dash kit in. i crimped them together and it works great now. |
Tipp City,
Ohio
Post Number: 7 Registered: Nov-07
| Posted on Thursday, January 24, 2008 - 06:35 am: |
Great. now be careful and don't get caught watching movies and driving... |
New member Username: Lchoate
Post Number: 1 Registered: Feb-08
| Posted on Saturday, February 09, 2008 - 09:08 pm: |
I used method 3 to unlock my XDVD8285. Worked like a charm. I have the ground switched so that if the police are near by, I can blank the video and the code does allow me to still effectively un-ground the wire and blank the video. Anybody aware of firmware upgrades or a method to load code on these units? I absolutely hate the way it works with my ipod. I'm also not thrilled with the menu system in general. If I had a method of loading code, I'd give it a shot. |
New member Username: Bamckychris4
| Posted on Tuesday, February 12, 2008 - 07:37 am: |
does anyone know the codes work for a xdvd700 i was going to buy one but decided to do some research first and haven found anythink working for that model if you have any info on that model please email me at bamckychris4@yahoo.com |
New member Username: Djblenda
IA
| Posted on Tuesday, February 12, 2008 - 03:45 pm: |
I just had Best Buy install a Dual xdvd 8281, are there any codes for this one so I don't need a switch? Hit me up at dan_beaver13@hotmail.com} |
Silver Member Username: Stateprop486
PA
Post Number: 391 Registered: Jan-08
| Posted on Tuesday, February 12, 2008 - 07:17 pm: |
dual dvd players suck period. |
New member Username: Keodie
Dub K,
Kansas
| Posted on Sunday, February 17, 2008 - 11:28 pm: |
hey guys iv been listening in and have put in a Dual xdvd700 but the thing is when i try the switch and click it ON the dvd movie comes on but only for a split second i try it again then it either does the same thing or it goes to the blue screen that says it has to be connected to the parking break but that also only stays on for a split second and it does this every time i try it. Any ideas anyone i would greatly appreciate it. Thanks |
| Posted on Tuesday, February 19, 2008 - 12:46 am: |
you have a horrible ground or your wiring is off |
Dub K,
Kansas
Post Number: 2 Registered: Feb-08
| Posted on Tuesday, February 19, 2008 - 02:03 am: |
Well I thought about that and I moved it to the units ground wire and its has continued and im pretty sure the wires are all correct I individually connected each color wire to the same color and triple checked it. |
| Posted on Tuesday, February 19, 2008 - 03:02 pm: |
are you sure the wiring is correct, i mean not that they arnt secure but are you positive that all the wires are connected where they are suppose to be? the wire from the headunits labeled parking brake should be to a good ground... the only other wires conected to be speakers, opt sub, opt antenna, and constant 12v and accessorie.. as long as parking is to a good ground, you should check to make sure you did the procedure correctly, some people it takes 2 or more tries... sometimes when it flashes on then goes off its cuz the unit isnt unlocked... it just gets a glimpse of the grounded brake but then doesnt bypass the restriction for video display... you myte also wanna double check if your model is able to bypass parking brake for video... check those and post back what you find... |
Dub K,
Kansas
Post Number: 3 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 12:43 am: |
ya know what I showed my friend that I bought it from and he was really confused and said it had to have been the screen on the player so we exchanged it from where he bought and got a new one and this one works lol thanks for all the suggestions tho i really appreciate it |
Dub K,
Kansas
Post Number: 4 Registered: Feb-08
| Posted on Monday, February 25, 2008 - 12:44 am: |
Im such a noob lol |
New member Username: Champaroo
| Posted on Friday, February 29, 2008 - 11:38 am: |
is there anyway to punch in the code withought a remote or does anyone know where i cold pick up a remote for the 8181 model |
Post Number: 5 Registered: Mar-07
| Posted on Friday, February 29, 2008 - 10:56 pm: |
you have to have the remote to punch in the code, and you can contact dual and request a new remote which will cost you a little money + shipping... or just hop on ebay and do a little searching... but whichever way, a remote is a must... even if you couls borrow a friends, it would work cuz the code is a 1 time thing and its permanant unlocked... |
New member Username: Connieh1968
Post Number: 1 Registered: Mar-08
| Posted on Sunday, March 02, 2008 - 08:47 pm: |
Has any one had a problem with it playing burnt dvd's? It will play some of mine but then some it will not, all were burnt the same way, same program. Any suggestion. I keep getting the error code, NOT COMPATIBLE FILE, but then when I take it and play it in my computer or dvd player, it plays fine. |
Post Number: 6 Registered: Mar-07
| Posted on Monday, March 03, 2008 - 12:01 am: |
depends if you use dvd-r and dvd+r and it also depends on how your comp burned the files, if you overburn (burn more then the disc capacity) with programs like nero then it will mostly not play... other then that i dont know why it wouldnt play... mine reads dvd+R and -R, has full touch screen for burnt custom music vid dvd's that i burn, and again i dont overburn and use almost all mpeg3/avi files only... hope this helps |
Post Number: 2 Registered: Mar-08
| Posted on Monday, March 03, 2008 - 05:26 pm: |
Can you tell me what program you use? I don't use Nero. I did use two different programs last night burning the same movie, one worked and one did not. I used DVD Fab to copy, then 1 Click DVD to copy. THis worked in the system, altho the ending froze up. Then I used DVD Next Copy and it would not play at all. |
Post Number: 3 Registered: Mar-08
| Posted on Monday, March 03, 2008 - 05:36 pm: |
Let me correct my post. I burnt the same movie twice. Once using DVD Fab to copy the movie, then 1 Click copy to burn to disk. I am using Memorex LightScribe, DVD+R. Then I used DVD Next Copy to do it all and it would not play at all. Can you recommend a different media that you have used and had not had problems with along with the software? |
PA
Post Number: 949 Registered: Jan-08
| Posted on Tuesday, March 04, 2008 - 10:13 am: |
i got 68 music videos on an dvd+r hahahaha |
Post Number: 7 Registered: Mar-07
| Posted on Tuesday, March 04, 2008 - 02:54 pm: |
i can only fit 40 on a dvd-r but that's including animated intro and hd quality videos (~90 mb each) |
Post Number: 8 Registered: Mar-07
| Posted on Tuesday, March 04, 2008 - 02:59 pm: |
connie - to be honest i use cheapo non lightscribe discs. the brand i use is windata-r but u can use +r as well and 100% playback everytime. i would recommend going to the store and just buy regular dvd+r/-r (non lightscribe or double layer) it could also be the way you rip the movie to your computer. format is always important. i would recommend trying to dl the video in mpg or avi n then burn it to disc n see if that works n if it does than it's the way ur copying the movie to the computer kiet |
Post Number: 4 Registered: Mar-08
| Posted on Wednesday, March 05, 2008 - 07:39 pm: |
Thank you so much for your replies, I appreciate it. I am using Memorex DVD+R, non lightscribe and an older program. So far, they are working great!! |
Post Number: 9 Registered: Mar-07
| Posted on Thursday, March 06, 2008 - 02:59 am: |
Connie - awsome to hear that... glad everything is working out, sometimes the littlest less technological things work out the best in the end... enjoi all the media and be careful not to let those eyes wander while driving =P |
Post Number: 5 Registered: Mar-08
| Posted on Thursday, March 06, 2008 - 11:05 am: |
Guess I talked too soon!! You never told me what programs you are using...I am mainly copying movies for my 2 year old. We had a unit installed overhead, but the dvd part broke, it never had problems reading anything I burnt. So we installed this Dual DVD700, I put another burnt movie in it last night testing it again, nope, skipped and all garbage. We were thinking about going to Jensen 9412? Any clue if a better "named" product would do better? |
Post Number: 6 Registered: Mar-08
| Posted on Thursday, March 06, 2008 - 11:22 am: |
I called the company to see if they could recommend something, he said mainly just had to hit or miss with the media and to burn at a slower speed. |
Bronze Member Username: Malicious01
Post Number: 11 Registered: Mar-07
| Posted on Thursday, March 06, 2008 - 06:55 pm: |
hmm... i use a program called NERO which is an exelent burning program... i ussualy use dvd FAB ti rip and NERO to burn(only copying what i own for my private use in my car), if it was a hit or miss case then its a hit every time... my setup is: sony optical dvd reader/burner/rewrite windata DVD -R and DVD +R DVDFAB HD Dycrypter is the program i use to rip to computer DVD Shrink to compress the video -OR- just burn with NERO, both takes equally long, Nero compresses for you which takes time, DVD shrink compresses but is lengthy as well, after compressed, NERO burns an about 5 minutes... |
Post Number: 7 Registered: Mar-08
| Posted on Thursday, March 06, 2008 - 07:23 pm: |
My husband went up to Circuit City, he took a stack of DVD that I have burnt, some that will work, some that don't. He put them in the new Phase Linear and the Jensen, they all played. So he bought a new one and will take this Dual back. Thanks for all of your help! |
Post Number: 12 Registered: Mar-07
| Posted on Friday, March 07, 2008 - 12:22 am: |
sounds great and np, glad to help out =P |
New member Username: Eclipseboy
| Posted on Friday, March 07, 2008 - 11:18 pm: |
brake over ride code for a pioneer avh-p4900dvd |
New member Username: Jason1413
| Posted on Saturday, March 08, 2008 - 01:00 am: |
i just installed a xdvd8181 but everytime i turn it on i get "signal not detected" being in camera mode. mode button wont work. everything worked fine when i tested it. only thing that is different is that i pluged in the iplug input. not sure what to do here, but this post has helped me with all of my other problems. |
Post Number: 13 Registered: Mar-07
| Posted on Saturday, March 08, 2008 - 03:12 am: |
danny - this is a DUAL bypass thread, so im not sure your gonna get any help on over ride code for pioneer jason heck - theres a small chance the unit is defective... i have had horrible experience with 8181 with cd/dvd getting stuck and the door stays open... id say exchange for a new one |
| Posted on Saturday, March 08, 2008 - 04:04 pm: |
thanks kiet i'll swap it out and see if that works. thanks a ton for your help. love, peace, and hair grease |
Post Number: 14 Registered: Mar-07
| Posted on Monday, March 10, 2008 - 01:00 am: |
np man, and jeez i havnt heard that phrase in a looong time =P take care and let me know how everything goes.. |
New member Username: Tangi
| Posted on Sunday, March 23, 2008 - 01:54 pm: |
I just installed dual xdvd-8285 in a isuzu rodeo. cd player is working but the fm tuner is not,it has a blue wire that is a power antenna.i have the regular ant wire in the rodeo can anyone please tell me how to fix prob......thank you |
Post Number: 15 Registered: Mar-07
| Posted on Sunday, March 23, 2008 - 02:07 pm: |
shawn sickler - you say you have a regular (non power) antenna?.. there should be an antenna wire that connects into your factory headunit (cd player/tuner). that antenna wire which is a thick audio looking wire should connect straight into the back of the DUAL xdvd8285 unit... if you do NOT have power antenna equipped on the car, that blue wire should be taped off because it is useless... make sure that the original thick antenna wire isnt loose in your dash, ive doe that a couple of times... if your factory unit recieved fm/am tuner then there was a wire which you need to connect to the new unit to recieve fm/am radio... hope this helps -kiet |
| Posted on Sunday, March 23, 2008 - 03:13 pm: |
Keit, Thank you for responding so fast,there is not a spot anywhere for the stock antenna wire. the only thing thing there is is a blue wire out of dual for a power antenna. how do i convert over to a power antenna ..thanks for all your help |
New member Username: Toointense57
| Posted on Monday, March 31, 2008 - 01:45 am: |
Im having an issue with my xdvd700. I am trying to burn music videos off of my computer onto a disk to watch in my car. however when I do so the disks work in my dvd player in my house, but when I put it in the player in my car it says "file not supported" any idea on maybe what I can do. I know this has nothing to do w/ the e brake by pass I figured that out on my own. I am just getting really frustrated with this not working and hoping someone out there can help me. thanks!!!! |
Post Number: 8 Registered: Mar-08
| Posted on Monday, March 31, 2008 - 10:46 am: |
Andrew, the best thing you can do is take it back and get a Jensen. We bought that same player a few weeks back. Every program I used and every way thinkable, I still had the same problem you do. Had my husband take it out and took it back, got the Jensen for $100 more and it plays everything! We took a stack of DVD's to the store and put them in to test them first. The Dual brand would not play any of them, the Jensen has yet to spit one out!! If you read above, I posted the same problem and one person tried to help me but I still had issues. |
Post Number: 16 Registered: Mar-07
| Posted on Monday, March 31, 2008 - 11:53 am: |
shawn sickler - you convert over to a power antenna by installing a power antenna ontot he vehicle... then connecting the wires for the power antenna up ie. power to power, blue wire to blue wire for headunit signal... Andrew Gomen - my experience with the sdvd700 is very slim... apparently alot of people are having trouble with burnt discs on this unit... i would say take connies advice and spring for a better unit... I have the dual xdvd8281 and it plays everything i throw at... sometimes i can burn crap discs out of mistake and it will still read wut i put on there (movies, home videos, music, mp3 disc, mp3 dvd disc, everything) Connie - hows the new player working out for you now? yeah some duals are crap, i guss the model i have is just lucky lol... i believe most of the newer in-dash duals play everything and after its ulocked it plays everything while driving... no issues with the last 2 duals i bought, maybe its a 700 thing... |
New member Username: Damaged
Post Number: 1 Registered: Apr-08
| Posted on Tuesday, April 08, 2008 - 05:59 pm: |
I have a Dual xdvd701, worked fine yesterday, other than playing DVDs with or without the parking break on. So I did the 3. DVD METHOD (Permanent) ** Insert a DVD ** Let it play until you hear sound ** Press STOP twice on remote ** Enter 26604 ** Press ENTER Worked great last night. but now since I got in the car this morning no DVDs will play, video or MP3 and I cant even access the DVD setting in the main settings. This sucks! Tried reseting it numerous times with the front little button as well as through the touch screen. Resets but still jacked! Anyone have this problem and know the solution?? Thanks a million in advance. J |
New member Username: Jb601
TN
Post Number: 1 Registered: May-08
| Posted on Friday, May 02, 2008 - 09:28 am: |
THIS MAY HELP Just purchased a Dual XDVD700 from Wal-Mart and installed it in my 96 Monte Carlo. Method 3 worked for me just fine. I simple used the ground wire going to my cigarette lighter since it’s a known good constant ground and in very close proximity to my installation area. I snapped and screwed everything back in place followed the simple steps outlined in method 3 and it worked like a charm. DVD-Video Format - I have a ton of music videos since I've have been using screen for many years now. After acquiring my video I simple convert it using Magic Video converter, converter the files to DVD-MPEG2, burn them using Nero to make a basic data disc with the converted file and it plays every round like a champ. Now if you want a high quality DVD use Roxio Media Creator 10. I create a DVD Jukebox and it allows you to create custom menus with ease and will do all the ID Tag and Case Pics for you. It plays just like a DVD except it is all music videos. I take mine a step further and get all the updated ID Tags first prior to using. Now you may want to give overnight to burn because believe me it’s in no rush. Once it’s done you will have an impressive DVD with all your music videos that are selectable like typical chapters on your movie DVD and provides not only track and artist info during playback, but pics of CD's cover. Now if you really want to go extreme....may I should just save that for a later post. One other thing, please keep in mind that DVD-Formats are selectable for a reason. A Mass DVD production uses a stamp to place information on disc and encodes it by regions. DVD Player Manufactures make sure their product will read that region. In our case we use a laser to scribe the information on the disc. Even though DVD manufactures can make a universal laser, but they don’t, to read these formats, they select a list of supported formats to program the ROM chip to read and leave it up to the end user to scribe their DVD using one of the supported formats. With this in mind, not all “home-Made” DVD will work in every DVD player mobile, portable, or home. Even though it may get a little expensive, it is good practice to test a few DVDs and DVD formats till you find the quality you seek. Use a good converter to avoid garbled, choppy, or low quality play back. This not only apply to this thread, but to anyone who’s scribing and encoding their own DVD’s at home. Hope this helps. |
Post Number: 9 Registered: Mar-08
| Posted on Monday, May 05, 2008 - 03:09 pm: |
Can you beleive I am having trouble again?? LOL I am using DVD Next Copy PRO to burn my movies...kids movies work great, all I can think of is that they are shorter, so they burn better? But when I try to do a full length movie, the first 20-30 minutes will play great, then they start acting up. Using Memorex DVD+R. I think I will go get some verbatim tonight...any clue?? |
TN
Post Number: 2 Registered: May-08
| Posted on Monday, May 05, 2008 - 04:28 pm: |
Hum, there could be several different factors involved. Trying a different DVD would be a quick and easy step. DVD Next Copy is an evolution of the older DVD X Copy. Unfortuantly I haven't toyed around with DVD Next Copy since I found a suitable program that I use. But my expericence with DVD X copy was a little troublesome that I would have liked it to be. DVD X copy allocates a certain amount of system (computer) memory and the total amount of the DVD buffer (or memory the dvd player/record has built in) When DVD X copy starts is process it attempts to make it as stream line as possible, so when the computer attempts to use the memory for another process it will cause DVD X copy to halt or slow down, causing it to gap and just mess a movie completely up. I would use another program. I use Clone DVD2 by elby along with Slyfox to back up my movies. Its really simple to use and uses a different memory allocation and retentsion process. I've backed my movies up to everything with this program. I had one issues, but that was due to my dvd burner going out. Hope this helps. |
Post Number: 17 Registered: Mar-07
| Posted on Monday, May 05, 2008 - 09:59 pm: |
connie - i would say like JB said, first step easily shoiuld be to use a different brand dvd+/-r ... then i would say if this does not change the quality output then you should try a different burn program, NERO works wonderfully with burning movies... you should sample the dvd's in your home stand alone dvd player first to view and defects in the quality... obviously if the quality is good on your home dvd player then once again it is the headunit problem... |
Post Number: 10 Registered: Mar-08
| Posted on Tuesday, May 06, 2008 - 06:27 pm: |
JB do you happen to have the links to those programs. I know most allow you to try them a few times first, I would do that then purchase them. Just to add a note, I have one computer that does nothing but burn dvd's. So there is nothing running along with the DVD Next Copy Pro to cause problems. I upgraded and that is when I think I started having the problems. But I am willing to try your mentioned softwares. Which one would I use first? THanks for all your help!!! I'm going to go tomorrow and get some verbatim dvd's. |
New member Username: Darkestcard13
| Posted on Sunday, May 11, 2008 - 02:57 am: |
ok first of all i used method 3 for my 8181 and it worked great so thanks for that. but i have a question for whoever might be able to help me out. I want to be able to put music videos on a dvd and watch them. But my 8181 wont read them. Can anyone please help me out with this. I read above how a few people can play music videos while others cant. So any suggestions would be greatly appreciated. Thanks!!!!! |
Bronze Member Username: Connieh1968
Post Number: 11 Registered: Mar-08
| Posted on Thursday, May 15, 2008 - 10:11 am: |
Bought some verbatim brand. Some skip, some doesn't, that's still using the DVD Next Copy. I bought DVD Shrink 08. Tried that and worked perfect a few times, now I can't get it to work at all, need to get in touch with the company. What about a double layer media? What are your takes on using that type to hold all the data? I downloaded the DVD Clone as JB has mentioned, but some of the DVD's are crypted (don't ask, I won't tell) so it doesn't allow me to copy! HELP?? Willing to spend the money to get it right!! |
New member Username: Night_hawk
| Posted on Sunday, May 18, 2008 - 11:46 pm: |
If you own a Dual XDVD8183 the easiest way to bypass the parking break safety feature is to simply connect the parking brake wire (yellow wire) and the reverse wire (white wire with the brown stripe) to the ground wireon the harness. Connect all of that to the ground wire on the car (the black wire attatched to the car). The unit will think that the parking break is engaged. I did it on mine and it worked perfectly. I do not know if this works with other Dual models. |
New member Username: Nelchis
| Posted on Tuesday, May 20, 2008 - 06:12 pm: |
HI I HAVE A STORE IN VENEZUELA AND I SELL DE DUAL DVD PLAYER FOR CAR MODEL XDVD 8181 I USED THE CODE METHOD 3 AND ITS WORK THANKS A LOT.... BUT I SELL ONE DVD PLAYER TODAY AND THE CODE DOENST WORK ? I PRESS THE NUMBER 26604 BUT IN THE MONITOR ONLY SHOW 6604 PLEASE HELP ME TO UNLOCK THIS DVD PLAYER THANKS A LOT |
New member Username: Bphunk
Post Number: 1 Registered: Jun-08
| Posted on Monday, June 09, 2008 - 03:35 pm: |
Dual XDVDN8290 Can anyone verify that this code and procedure works for the Dual XDVDN8290. I am looking to buy one and want to know if I can disable to safety measure. Dual XDVDN8290 |
New member Username: Radrhino07
Humble,
Tx.
| Posted on Thursday, June 19, 2008 - 09:22 pm: |
Ok stupid question here, but which one is the stop and which is the enter. |
New member Username: Dtilson
Post Number: 1 Registered: Dec-08
| Posted on Saturday, December 13, 2008 - 06:16 pm: |
okay, so i just got a dual xdvd700 as an early christmas gift, i decided to just google it and see what all was said abiut it, after reading this im wondering if maybe the xdvd700 isnt good. i must say i am only 16 and i am new to driving so i wont be needing to watch and dvds while driving. So the issues with the 700 not playing burnt dvd isnt an issue to me. So other than that is the xdvd700 an okay gift. I dont want to be stuck with a crappy player. Are there any other problems that have come up with the xdvd700??? Please let me know. |
New member Username: Karmahkid
| Posted on Wednesday, December 17, 2008 - 01:25 pm: |
Hi folks, I received my Dual XDVDN8190 yesterday from Crutchfield and installed in my Jeep Overland last night. I grounded the e-brake wire to the ground on the harness, powered it up, popped in a DVD and bam it played no problem. I went ahead and followed the instructions from "3.DVD Method" above and it also worked. Thank you!! |
New member Username: Emtmike
Tennessee
| Posted on Friday, December 26, 2008 - 10:53 pm: |
26604 worked for me on my Dual XDVD 700. It's been flawless so far... Got the p-Brake wire permanently grounded to the power-point outlet, as it was convenient to the H/U just behind the dash on my truck. |
New member Username: Mudiechick13
Post Number: 1 Registered: Jan-09
| Posted on Saturday, January 31, 2009 - 04:01 pm: |
Hey guys I just got a new XDVDN8190 and i am trying to get the dvd to work without that e-brake wire connected. I grounded it out to the ground from the wire harness and entered the code you guys got and I can't get it to work? Am I doing something wrong or is there a different code for my stereo? Can someone help me? |
New member Username: Thebombmp
Las vegas,
Nv
Usa
Post Number: 1 Registered: Feb-09
| Posted on Friday, February 13, 2009 - 04:21 am: |
i just ordered the dual xdvdn8290, can anyone help me with the dvd bypass |
Post Number: 2 Registered: Dec-08
| Posted on Friday, February 13, 2009 - 10:36 am: |
Hey Crystal, I also have the XDVD8190 installed in my Jeep. I performed step #3 without grounding the ebrake wire first but no luck. I then temporarily grounded the ebrake wire directly to my truck on the frame under the dash just to verify that it worked. I then followed step #3 again and voila, it worked! Let me know if you still cannot get it to work. |
Post Number: 2 Registered: Jan-09
| Posted on Friday, February 13, 2009 - 06:29 pm: |
Hey Jeremy Thanks for getting back to me I got it figured out now. But I have a new question for ya... Does your stereo, when you turn your jeep on, come on louder then when you shut it off?? And sometimes when you start your vehicle is there no sound at all cause it happens to me quite frequently and if i can get it to shut off, Cause sometimes it dont want to shut off it just beeps at me, it will have sound again. Can you please help me with this one I dont know what to do and its really bugging me!!!! |
New member Username: Djanim8
| Posted on Wednesday, February 18, 2009 - 08:39 am: |
Bobby: Dual XDVDN8290 Can anyone verify that this code and procedure works for the Dual XDVDN8290. I am looking to buy one and want to know if I can disable to safety measure. Dual XDVDN8290 I just purchased the XDVDN8290 and option 3 worked. I didn't think it was going to.... but I got to the menu screen on the DVD and did it, and it worked fine. |
New member Username: Jorgeduardo
| Posted on Thursday, February 19, 2009 - 05:28 pm: |
Does anyone know how to connect an Ipod Classic (6th generation) with a Dual XDVD8183 in order to have full control and video support on screen?? |
New member Username: Demond
Post Number: 2 Registered: Feb-09
| Posted on Wednesday, February 25, 2009 - 07:15 pm: |
I put in the code for the xdvd710 26604 and blue screne still come on when ebreake is up but plays when it is down |
New member Username: Allnatual
Post Number: 1 Registered: Apr-09
| Posted on Monday, April 20, 2009 - 11:17 am: |
How are you guys doing? I'm new to this forum so bare with me. 1) I own Dual xdvd8183. Is the a on/off switch for subs? Can you turn them off completely? In eq section you can only minimize the bass. 2) When I'm going to speaker menu, I cannot switch to 6 channel setting. Why is that? Thanks Alot!!! |
Bronze Member Username: Rainnaunseque
Post Number: 28 Registered: Dec-08
| Posted on Wednesday, May 13, 2009 - 03:44 pm: |
no need |
