Thread: INFINITY REFERENCE?? |
Silver Member Username: Jaackdeth
United States
Post Number: 708 Registered: Sep-04
| Posted on Friday, December 15, 2006 - 12:18 pm: |
Anyone know anything about these amps 1211a? Looking to run a 15" SE with it. Thanks |
United States
Post Number: 709 Registered: Sep-04
| Posted on Friday, December 15, 2006 - 12:20 pm: |
Make that a 15" SX |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3726 Registered: Dec-05
| Posted on Friday, December 15, 2006 - 04:32 pm: |
should put more than 1200wrms. Seriously, for the same money you can get jbl gto1201.1 better quality and the output is almost the same |
United States
Post Number: 710 Registered: Sep-04
| Posted on Friday, December 15, 2006 - 09:31 pm: |
Your saying that JBL is better then the Infinity? |
Post Number: 3729 Registered: Dec-05
| Posted on Friday, December 15, 2006 - 10:45 pm: |
is more reliable and the infinity is even more expensive. |
United States
Post Number: 711 Registered: Sep-04
| Posted on Friday, December 15, 2006 - 11:12 pm: |
ok, thanks |
New member Username: Alanpflanz
Post Number: 2 Registered: Dec-06
| Posted on Friday, December 15, 2006 - 11:44 pm: |
i just bought and new car. i want to put in the system that i had in my other car. but i dont know how to hook it up. i dont want to change out the head unit. i have everything for the car. i need step by step help. thanks} |
