Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Easy question
Author Thread: Easy question
Username: Holt_champ
Htown, MI
Post Number: 393
if i use a distribution block will that let less current to my amp then just wiring the 1/0 gauge to it?? thanks!!
Username: Jaackdeth
United States
Post Number: 704
It shouldn't.. Just don't make the run of smaller gauge wire so long.
Htown, MI
Post Number: 396
i was goin to put it right next the amp
Username: Jaackdeth
United States
Post Number: 705
That should be fine, that's what they make the blocks for.
Htown, MI
Post Number: 397
i have been lookin and they are like 20 bucks. is there anywhere to get them dirt cheap??
Username: Loc_out
Santa Ana, Ca
Post Number: 584
try ebay.
Username: Loc_out
Santa Ana, Ca
Post Number: 585
try ebay.
Htown, MI
Post Number: 399
alright thanks
Username: Jaackdeth
United States
Post Number: 706
Also do a google search, sometimes you can find a deal, good luck.
Username: Lbeckner
Tulsa, Ok
Usa
Post Number: 1392
u can get one with 2 x 1/0 and 3 x 4ga. then u can still run 1/0 to the amp.
Htown, MI
Post Number: 401
well my problem is that i can find any ring terminals that will fit on the amp so i need need 4 awg to connect through a dist. block.
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Easy question [ « Previous ] [ Next » ]
