Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Starting problem - Dodge Ram 2500 (20...
Author Thread: Starting problem - Dodge Ram 2500 (2005)
Username: Acousticar
Kibworth, Leicestershire
United Kingdom
The vehicle will not start and run, it started and ran for approximatley 2 seconds a handfull of times but now will not start at all. does any one have any idea why? need urgent reply please.
Username: Ccdoggy
Post Number: 86
what happens when you try and start it? does it make a clicking sound? or nothing at all?
if its clicking check that you're battery is good and contacts are good goin to the starter.
Its newish... take it to the dealer and warranty it. They will take care of it.
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4543
get some batt cleaner and clean the batt posts to take off the possible corrosion. it should be bright silver
Username: James1115
Use a simple...
Post Number: 8090
could be many things, if it is a 2005, bring it to the dealer.
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Starting problem - Dodge Ram 2500 (20... [ « Previous ] [ Next » ]
