Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > SPL Z1X - 3000D SERIES II
Author Thread: SPL Z1X - 3000D SERIES II
Username: Jaackdeth
United States
Post Number: 693
Anyone know anything about these amps? Any good? I see the price isn't much so I take that as a no unless someone has some info. Thanks
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3703
it's a powerful amp. The quality is not the greatest and the model is overrated, but i think it comes with a 160A fuse. What are you planning to push jack??
Username: N2audio
Lawrence, Ks
Post Number: 1044
same on the inside as the Power Acoustik a3000db
at least one person on this forum is real happy with theirs.
Username: Jaackdeth
United States
Post Number: 696
Well I had an Orion 2500d and was using it to push a RE 15" SX in a ported box. It sounded fantastic, but I had the amp stolen, and put in an Audiobahn 8000t that a friend let me use, and it sounds like crap with that amp. It's like it's hitting it ok, but the sound is real ill sounding. So need to get another amp, but don't want to make a mistake. I would rather not spend another $500 to do it if possible. Thanks
Username: Jaackdeth
United States
Post Number: 698
Anyone else?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3713
well, i'd consider SS picasso 2000D but is up to you
Username: Jaackdeth
United States
Post Number: 701
You think I need that much to run that 1 sub?
Username: N2audio
Lawrence, Ks
Post Number: 1047
"You think I need that much to run that 1 sub?"
No, but the 2500D was even more powerful.
and the 8000T SHOULD have sounded like crap, you were either stressing it at 1 ohm, or way underpowering your sub at 4.
I think the pca1000D or 1500D would be more than enough, the spl 2400D would work well too.
Username: Naledge503
Qnited States of FI Ca...
Post Number: 746
Opti, I think it was me that you were talking about, with the a3000db. I seen your post in another thread about the PA DB line. How you wont be impressed by the name but by the power. 100% true. Have you ever benched any of the DB line. On caraudio forums they talk about it alot. And they say it is a very decent amp. From what I have read (believe me I have tried to find out as much as possible about my amp) They do not do too much less than their rated power.
Username: N2audio
Lawrence, Ks
Post Number: 1050
termpro.com does a lot of power tests, and from what I've seen the A3000db is right around 2kw.
Post Number: 750
Thanks Opti. I did a little search over there and I like what I see. Alot more positive than negative.
Username: Jaackdeth
United States
Post Number: 702
Opti, Thanks. The reason I had that Orion amp hooked up in the first place was that I got a good deal on it, and was going to run a differnt config with it.
All that aside, the sub I have is wired for a 2 ohm load, so that Audibahn would run it, but not very well. So you think that SPL would be as good as the SS? Thanks
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3719
in output, yeah. Jesse or opti, do you guys have a link for the PA benchtest
Post Number: 758
Julio, here is a link to the search for the pa a3000db. read through those.
http://audioforum.termpro.com/cgi-bin/ubb/ubbiquery.asp
Username: N2audio
Lawrence, Ks
Post Number: 1053
"the sub I have is wired for a 2 ohm load"
I only saw the sx available as a dvc 2, you have a dvc 4?
Username: Jaackdeth
United States
Post Number: 707
Yes, I bought it from a guy who had ordered it from RE that way.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3723
well jesse D that link showed me many results. 2200w rms at 1 ohm for the a3000DB so it is the best amp for the money i think
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > SPL Z1X - 3000D SERIES II [ « Previous ] [ Next » ]
