Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Infinity Kappa?
Author Thread: Infinity Kappa?
Username: Vash3000
Post Number: 9
Anyone know if the Infinity Kappa speakers are any good? The Infinity Kappa 60.7 CS series or the 62/63.7I series. I dont know if I should spend $50 more to get the component series or should i just get the regular 3-way speakers? Is there a big difference between the two in terms of clear sound? And what about the reference models, are they any good compared to the kappa?
Username: Dsmith07
LaGrange, NC
US oF A
Post Number: 304
the components are going to give you a much better sound IF you are gonna run them on a amp...its not recommended to run comps off the head unit with the comps your going to get better midbass and better highs but like i said thats if you run a amp on them if your planning on using the headunit i'd say stick to the coaxils.
Username: Vash3000
Post Number: 11
I am planning to run a Kicker 350.2 amp on the speakers, but I don't know if I should spend an extra $50 on the comps if the coaxils can sound pretty similar to the comps.
Username: Tjmutlow
Post Number: 3369
get the components
Home > Message Board > Car Audio > Speakers > Archive through December 20, 2006 > Infinity Kappa? [ « Previous ] [ Next » ]
