Thread: PA a1000db vs audiobahn a8000t |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3697 Registered: Dec-05
| Posted on Wednesday, December 13, 2006 - 05:08 pm: |
hey guys i'm trying to make a budget system for a friend here. He needs 800w rms at 2 ohms and i tried to convince him for a kicker zx 750.1 but it was out of his budget. I told him i could find a solution and here it is: PA a1000db (800w rms at 2 ohms, 3x30A fuse and it's 1 ohm stable although the specs don't say it) Audiobahn a8000t (i was going to pick this right away but i'm not sure if the amp will put 800w rms at 2 ohms. It has a cooling fan, but i really need 800w rms at 2 ohms, not 600w like some guys said about this amp) I think the PA is power wise and the Abahn has better quality. Let's hear your reviews on each one. |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 4519 Registered: Oct-05
| Posted on Wednesday, December 13, 2006 - 06:01 pm: |
well, the PA isnt one ohm stable. it 2 ohm, and it would only be able to run 1 ohm for a short amount of time. really, its hard to say, because birth sheets for both amps cannot be found, so you just have to go by what the manufactur claims, which wont happen. the a bahn will do pretty close to 800. prolly like 700, the PA prolly around 750 |
Post Number: 3699 Registered: Dec-05
| Posted on Wednesday, December 13, 2006 - 06:32 pm: |
bassman, the amp specs don't say the amp is 1 ohm stable, but i read many reviews about people running them at 1 ohm for daily driving without problem. And nowadays i've found many sellers on ebay claiming the amp is 1 ohm stable. I might grab the PA, bigger fuses and might have the chance to wire it at 1 ohm. more opinions?? |
Tigard,
OR
U.S.
Post Number: 4521 Registered: Oct-05
| Posted on Wednesday, December 13, 2006 - 07:03 pm: |
i just would never run an amp @ an ohm load that it doesnt state it can run at in the specs. |
Post Number: 3701 Registered: Dec-05
| Posted on Wednesday, December 13, 2006 - 08:17 pm: |
??? more opinions???? |
Silver Member Username: Naledge503
Qnited States of FI Ca...
Post Number: 733 Registered: Jun-06
| Posted on Wednesday, December 13, 2006 - 08:21 pm: |
Come on julio whats up? Your the king of budget....haha. I personally like my a3000db. I dont really care what people say about it. I have the personal experience with it. Unlike 99% of the people who hate on it. Oh yeah...and its lasted a hell of a long time. |
Post Number: 3702 Registered: Dec-05
| Posted on Wednesday, December 13, 2006 - 10:20 pm: |
yeah, i think i'm the king hehe lol! but i was really thinking the a-bahn just because of the cooling fan. The weather is very warm here. I think i'll grab the PA. It's not for me anyways. A newbie can't tell... |
Tigard,
OR
U.S.
Post Number: 4527 Registered: Oct-05
| Posted on Thursday, December 14, 2006 - 12:04 am: |
lol. your a nice friend then. and yes the a bahn has a cooling fan, but i think thast fan actually causes some over heating problems + the heatsink is chrome = no heat dissipation |
Gold Member Username: Tjmutlow
Post Number: 3367 Registered: Sep-05
| Posted on Thursday, December 14, 2006 - 09:09 am: |
just because you run an amp or people run an amp at what it is not rated at, does not mean it is good for the amp, there is a reason these manufactures rate the amps at what they do. |
