Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > What size fuse for my power line?
Author Thread: What size fuse for my power line?
Username: Bassfiend
Post Number: 28
I have a single 12" Alpine Type X DVC (4ohm+4ohm)
and a
Hifonics Titan TX-1505d 1000w Mono-Block Amplifier,
My alpine is wired at 2ohm and I'm running 1000w rms to it...
and a 4 gauge amp kit
I just need to know what size fuse to put in the in-line fuse holder that powers my amplifier..
So what size??
Thank you... :-)
Username: N2audio
Lawrence, Ks
Post Number: 1043
Username: Hgihkcin
Post Number: 40
to be on the safe side go with the 100 and if gets blown easy go up one higher and so on and so on, fuses are cheap buying a new amp after you fried it isnt
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3698
why are you getting a 100A fuse taking the risk that you might blow it nick. Play safe and get a bigger one. I don't see the point of your post nick. Do it right the first time
Username: Bassfiend
Post Number: 29
so 100 amp it is?
Username: Shortysetnies
Rock Vegas, NC
US
Post Number: 710
play it safe and get a BIGGER one? WTF are you talking about julio?
Username: Sinful_systems70
Post Number: 171
What is the fuse rating on that amp. What and how many fuses are on the side. I would have to say it will probably have 2 60A fuses on it so I would go with 120A-125A.
It is safe to go 5A over and still be safe. Some reccamend for a 5A overage to have less unnecessary fuse failures.
60A fuses x 2 = 120A SO Go with 125A
Username: N2audio
Lawrence, Ks
Post Number: 1055
"It is safe to go 5A over and still be safe. Some reccamend for a 5A overage to have less unnecessary fuse failures. "
really? New one on me.
Did you dream that one up all on your own??
IF you know anything about fuses you know they can pass 2x their rated current dynamically.
SO yeah, 125A will work. 120's fine. 100A will work just fine too, and provide more protection against over-current. Not that it matters, but chances are 80A will probably get it done as well.
But by all means - 125A is the way to go since that's the new Sinful Systems "rule".
Post Number: 172
There is nothing wrong with what I said and none of it is made up.
Username: Safe_cracker
Chicago, IL
US
Post Number: 2186
Kicker recommends 4ga for there sx1250.1 and they provide a 150A fuse....:-) Polo..
Username: Tc_skier
Post Number: 54
i have to second andrew....juliob back to the basics man...how fuses work...your post didnt make any sense at all.
http://www.bcae1.com/
#14 right hand side is fuses. read over it before you blow anything on your system.
Username: Miho1379
Austin, Texas
United states
Post Number: 17
i would def. say just go with the 150A
becuase i use to have that same amp for two diamond audio TDX D9 10"s and i had a 100A and it blew in the first couple of weeks i upgraded to a 150A and it never blew for a few months until i sold my system
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > What size fuse for my power line? [ « Previous ] [ Next » ]
