Thread: Popping fuses... |
New member Username: 218
Post Number: 2 Registered: Nov-06
| Posted on Wednesday, December 13, 2006 - 01:17 am: |
My eD nine.1 was sounding good for about a hour with my 15" dual 2 ohm comp VR's until it suddenly cut out. I pop my trunk, and see all four 30 amp fuses in my amp had blown. I check all my wiring, replace the fuses, and turn the system back on, the fuses pop again instantly. I disconnect my speakers, recheck all my wires again, and replace the fuses 1 more time. Again they pop instantly when the amp turns on. Running 0 gauge wires, and have an Eclipse CD2000 deck. Any ideas?? |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 4513 Registered: Oct-05
| Posted on Wednesday, December 13, 2006 - 12:44 pm: |
well, the nine.1 is 1 ohm stable, so you need 2 dual 4 ohm subs to run it @ 1 ohm... you cant run @ 1 ohm with 2 dual 2 ohms. unless you have it wired to 2 ohms |
Post Number: 3 Registered: Nov-06
| Posted on Wednesday, December 13, 2006 - 02:14 pm: |
Not trying to run it at 1 ohm. Wired for 2 ohms. Gonna drop it down to 1 when I get another 15" tho. |
Tigard,
OR
U.S.
Post Number: 4518 Registered: Oct-05
| Posted on Wednesday, December 13, 2006 - 03:04 pm: |
then the gain on the amp needs to be down alot more... its called eithr the gain or the "level" on some amps |
Silver Member Username: Qbenjamin
Florida
Post Number: 132 Registered: Nov-06
| Posted on Wednesday, December 13, 2006 - 03:05 pm: |
hey 218, that same thing happen to my Orion 1200D, eventually that infamous white cloud of smoke will come out of your amp, so stop trying to hook it up and send it back to the Manufacturer if you have a valid warranty!! Hope this helps you out. |
Gold Member Username: Lbeckner
Tulsa,
Ok
Usa
Post Number: 1388 Registered: Oct-04
| Posted on Wednesday, December 13, 2006 - 03:29 pm: |
if you do hook it back up then only use one 30 amp fuse instead of all four of them. that amp shouldn't blow one 30 amp fuse with no music playing through it. This way you will be less likely to cause the white smoke while you are trying different stuff. |
