Thread: Rockford 5002 |
Bronze Member Username: Bryan333
Post Number: 67 Registered: Nov-06
| Posted on Tuesday, December 12, 2006 - 03:06 pm: |
Is it a good amp? Im looking to power two 10" type-r's with it |
Post Number: 68 Registered: Nov-06
| Posted on Tuesday, December 12, 2006 - 03:08 pm: |
o yah i forgot to mention, using it @ 2 ohms |
Gold Member Username: Tjmutlow
Post Number: 3360 Registered: Sep-05
| Posted on Tuesday, December 12, 2006 - 03:14 pm: |
if the p sereis, then prob not if the new subs, they are 500w rms. |
Bronze Member Username: Jeromebaker
Post Number: 32 Registered: Dec-05
| Posted on Tuesday, December 12, 2006 - 08:23 pm: |
Better to run it at 4 ohms than 2. At four it'll put out about 450 rms, at 2, like 125 per channel. You can't bridge this amp at 2 ohms; It will overheat and shut off. |
Post Number: 71 Registered: Nov-06
| Posted on Tuesday, December 12, 2006 - 08:28 pm: |
well, when I search rockford 5002 I get this amp http://www.rockfordfosgate.com/ez2/fcsscripts/Images/Rockford/2004/Amplifiers/Po werT5002_F.JPG and this amp http://shop.extremeaudio.de/images/rockford/DSC00077.jpg the second one is the one I am talking about, and I read its 500watts RMS to each sub at 2ohms |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3687 Registered: Dec-05
| Posted on Tuesday, December 12, 2006 - 09:57 pm: |
well, if i'm not mistaken, type Rs are 500w rms each. Are they DVC 4 ohm or 2 ohm you'll need a 1000w rms amp |
Post Number: 33 Registered: Dec-05
| Posted on Wednesday, December 13, 2006 - 01:53 pm: |
I messed up my first post. That amp should put out about 550 rms (on a bench test. Rockford's strict w/ratings). But only when it's bridged at 4 ohms. Not run at 2 channels. And it's not stable bridged at 2 ohms. These are the ratings on that amp: 125 W x 2 @ 4 Ohms RMS 250 W x 2 @ 2 Ohms RMS 500 W x 1 @ 4 Ohms bridged RMS ...You're gonna be underpowering your subs. |
Post Number: 3365 Registered: Sep-05
| Posted on Wednesday, December 13, 2006 - 03:02 pm: |
that is a p sereis amp |
