Thread: What amp should i get |
New member Username: J_mack
Houston,
Tx
US
Post Number: 6 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 11:10 pm: |
what kinda amp should i get if i hav two 12's with 1500 watts each |
Gold Member Username: Ctmike
Ct.
Post Number: 2677 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:15 pm: |
1500w each. would that be rms or peak? post the rms cause peak doesn't mean anything. and vc of the subs. |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 10741 Registered: Jul-05
| Posted on Sunday, December 10, 2006 - 11:17 pm: |
what kind of subs??? vc configs? |
Houston,
Tx
US
Post Number: 7 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 11:29 pm: |
the rms is 3000 |
Ct.
Post Number: 2682 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:31 pm: |
and vc config. would be...? |
Houston,
Tx
US
Post Number: 8 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 11:34 pm: |
dual |
Ct.
Post Number: 2683 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:39 pm: |
dual 2 or 4? and before this gets dragged out longer waiting for the answers i'll just ask: budget? do you do used/ebay? do you have the charging system upgrade for all this? |
Houston,
Tx
US
Post Number: 10 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 11:46 pm: |
yea its on ebay and whats the charging system upgrade do u want me to send u a link |
Ct.
Post Number: 2684 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:51 pm: |
1) you need to post the specs of the sub/s you have i.e. the rms (not peak), the vc config (dual 2, dual 4, single 4, etc., brand is good. 2)budget. please post this before everyone starts suggesting amps that are say $500+ and 5 hours later you say it's only $150. 3)you buying brand new from dealer or online, used, ebay? 4)upgraded charging as in high output alternator, battery/ies, do the bug three. to run that amount of power you have to do it. might make you change your system plans. |
Bronze Member Username: J_mack
Houston,
Tx
US
Post Number: 11 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 11:54 pm: |
thanks |
