Thread: Orion 2500d!! |
Silver Member Username: Akamigs
Post Number: 102 Registered: Apr-06
| Posted on Sunday, December 10, 2006 - 09:30 pm: |
I just got an orion 2500d amp and it only takes 4 guage power wire. I need to make 2 runs of 0 guage wire, so should I just shave the ends that go into the amp so that they fit into the holes? If not what should I do? |
Silver Member Username: Devastation101
Audioque SD2.5-ville,
HENDERSON, NC
US of A
Post Number: 497 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 10:43 pm: |
Get a distribution block. Some should allow you to run 0 gauge in one end, and 4 or smaller gauge out the other, |
Silver Member Username: Oneracistguy
TWO EGG,
FL
Post Number: 103 Registered: Sep-06
| Posted on Monday, December 11, 2006 - 04:48 pm: |
just use one run of 1/0 into a distro block to 2 4 gauge thats what i used on mine and it works perfect |
Bronze Member Username: Dj_007
Carlisle,
KY
US
Post Number: 26 Registered: Dec-06
| Posted on Monday, December 11, 2006 - 09:32 pm: |
there is no possible reason to have to run two runs of 0 gage wire for that amp.. its powerfull and all but doesnt need that much.. one run should be plenty enough.. |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 2144 Registered: Jan-06
| Posted on Monday, December 11, 2006 - 11:11 pm: |
Get a set of reduction pins if you want to go staright with a 0ga run. They look like brass pins on one end and have a hole on the other with a set screw for the 0ga wire. Polo..  |
