Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Need som help
Author Thread: Need som help
Username: Starpath
ok i wana hook up 2 amps a cap in my iszusu amigo lol i have a 2400 watt amp for my 15 earth quake and i have a 1000 watt amp i wana hook up to my 6x 9 and i have i forget what size the speakers are btu there the ones below 5.25 and a cap i was wonderign if any of u have any wire diagram im not too goood in words but a pic would b nice to hook them up in my car hehe
Username: Starpath
anyone have a ny clue how to hook up the wire from battery to fuse thing then the diibrution block with i think splits the wire the 1 i have has 4 hose then get what 8 gage and run it to the cap? or put the cap before the disbrution block so it would b battery fuse cap then the block or what and use 4 gage from battey to cap and 4 gage from cap to disbrution block then 8 gage from block to both amps ? not cure lol and also once thats hoocked i get speakers wire from 6x9 and the 5 .25 and hoock them up to the 1 1000 watt amp and the other amp to my 15 inch sound right or what am i missing
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3676
why are you using a cap?? do you have a high output alternator??
als ocan you post the brand of your amp, model, specs and your subs too
Username: Starpath
earth quake 1 15inch sub
earth quake 2 6x9 800 watt
earth quake 2 5.25 300 watt
earth quake 2 4.00 200 watt
cap 1 3 ferat
pyle 1 2400 watt
american pro 1 1000 watt
Username: Starpath
american pro is 4 channel and no if you call a original 94 amigo alternator high out put then id say no lol
Username: Ctmike
Ct.
Post Number: 2680
and please post the rms for the subs/amps.
Username: Starpath
4" 2 2 way
200 Watts Max
- Frequency Response 50Hz-22kHz.
- 4" fiber impregnated polymica cone, super wide edge rubber surround
- Sensitivity 89dB.
- 0.75" swivel dome tweeter, neodymium magnet
- Poly-switch tweeter protection
5.25 2 way
300 Watts Max
- Frequency Response 30Hz-22kHz
- 5.25" fiber impregnated polymica cone, super wide edge rubber surround
- Sensitivity 90dB
6X9" 2 way
600 Watts Max
Frequency Response 20Hz-22kHz
6"x9" fiber impregnated polymica cone, rubber surround
Sensitivity 91dB
2.5" Midrange
Polyswitch tweeter protection
Username: Starpath
Magma 15"
1500 Watts Max
*FS=26Hz
* Qms = 3.5313
* Qes = 0.4603
* Qts = 0.4072
* VAS = .75Ft3
* Xmax = 0.5"
* 85dB 1W/1M
* Revc = 6.78
* Levc = 6.3mH @ (1 kHz).
* 3" Dual Voice coil(2x3.2-ohms
i think this is it not sure im check it out tomrrow
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Need som help [ « Previous ] [ Next » ]
