Thread: Rockford fosgate 1001bd |
Bronze Member Username: Beetleboyz2005
NC
Usa
Post Number: 42 Registered: Mar-05
| Posted on Sunday, December 10, 2006 - 10:04 am: |
hey i have a chance to get this amp from a friend for 120 dollars ,im askin are they really any good, its a fockford fosgate 1001bd. |
Silver Member Username: Devastation101
Audioque SD2.5-ville,
HENDERSON, NC
US of A
Post Number: 478 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 10:51 am: |
Hey what part of NC are you from? And yes they are good amps! |
NC
Usa
Post Number: 43 Registered: Mar-05
| Posted on Sunday, December 10, 2006 - 11:04 am: |
sanford hey and thanks |
HENDERSON, NC
US of A
Post Number: 479 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:10 am: |
no prob, if you get it, what kinda subs are you going to hook it up to? |
Gold Member Username: James1115
Use a simple...
Post Number: 8038 Registered: Dec-04
| Posted on Sunday, December 10, 2006 - 11:12 am: |
yeah if you dont buy that, I will |
HENDERSON, NC
US of A
Post Number: 480 Registered: Feb-06
| Posted on Sunday, December 10, 2006 - 11:47 am: |
Hey James, those BD series amps aren't 1 ohm stable are they? |
Gold Member Username: Suleman36
Post Number: 4140 Registered: Feb-05
| Posted on Sunday, December 10, 2006 - 12:45 pm: |
The BD power series are great amps and yes they are 1 ohm stable. I may be selling my RF Power 1000 5 channel limited amp. ;) |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 10736 Registered: Jul-05
| Posted on Sunday, December 10, 2006 - 12:47 pm: |
BeetleBoyz...it says u have CrossfireVR1000d...sell me 1 |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 3677 Registered: Dec-05
| Posted on Sunday, December 10, 2006 - 08:59 pm: |
depends on the BD model. If those are the older ones, i think they're 2 ohm stable. If it's the t10001bd then is 1 ohm stable |
