Thread: Alpine 3527 wont turn on but power goes to it |
New member Username: F6mafia
Post Number: 1 Registered: Dec-06
| Posted on Saturday, December 09, 2006 - 10:05 pm: |
i have a alpine 3527 and there is power that goes to it but it wont turn on and i cut all of the wires off so im pretty sure it isnt shorting and i used a meter and there is like 12.35 volts going into the amp and it has a good ground do you have any ideas??? |
Gold Member Username: Dustin3
Tigard,
OR
U.S.
Post Number: 4487 Registered: Oct-05
| Posted on Saturday, December 09, 2006 - 10:50 pm: |
so its just not turning on? where did u hook up your rem wire? and make sure you have a very good ground |
Post Number: 3 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 03:29 pm: |
ya i just doesnt turn on and i think the rem wire goes into the back of the cd player im not sure what that is though and i tested the ground and it was good. could it just have died somehow casue it shorted out like 6 times cause the transistor cracked |
Post Number: 4 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 07:25 pm: |
and i ripped out the bad transistor |
Post Number: 5 Registered: Dec-06
| Posted on Sunday, December 10, 2006 - 07:27 pm: |
and i ripped the bad transistor out but it still didnt work before that |
