Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Someone help please
Author Thread: Someone help please
Username: Jack1808
Post Number: 13
ive been having troubles with my sub...ive tried two different amps but still the same thing happens. i cannot wire my sub at 2ohm..only 4. if i do wire it at two my sub goes hay-wire. ive got it wired at 4ohms right now, when i touch the medal on my amp the sub goes in and out. Im guessing its to do with wiring but ive checked everything i can think of. if anyone has any suggestions it would be a help.thanks
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4485
whats the VC configuration and ohm of ur sub. and do you have 1 or 2 subs?
what amp are you trying to connect?
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4486
bump
Username: Jack1808
Post Number: 14
well ive got a 12' cvr..and ive got a older zrx360 amp.
Username: Dustin3
Tigard, OR
U.S.
Post Number: 4495
is the cvr dual 2 ohm, or dual 4 ohm?
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > Someone help please [ « Previous ] [ Next » ]
