Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > HCCA 250G4 vs. Memphis MC1000
Author Thread: HCCA 250G4 vs. Memphis MC1000
Username: Mvplefty12
Pinellas, FLA
America
Post Number: 372
Ok, I'm considering buying James Orion amp, and I want to know how it compares to the Memphis MC1000 as far as output and SQ. It will be used to power a 15" S.I. Mag. Any opinions?
Thanks,
Andrew
Username: Tjmutlow
Post Number: 3345
the orion is rated at 800w at 1 ohm, but prob does a little more then that.
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3651
old school orion is better than memphis, although i'd pick the memphis. The quality is good and the output is the same. plus you can get a warranty from memphis
Username: Southernrebel
Monroe, Louisiana
DD 9515d~~]...
Post Number: 3976
i would go w/ the memphis.
more efficient and will produce alil more power.
Username: James1115
Use a simple...
Post Number: 7852
the memphis will put out more power but the orion is a killer old school competition amp that is extremely versatile:-) it does 50x2 to 400x2 and 200x1 to 800 x 1 all at 12 volts. you really cant beat it in versatility. If you ended up using your memphis for your subs the orion is a amazing mids and highs amp:-)
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 3657
yeah james, but remember the warranty. The memphis will put the same amount of power with warranty and brand new. That's hard to beat
Username: James1115
Use a simple...
Post Number: 7960
he already has the memphis so he is not comparing a brand new one to it.
Username: Suleman36
Post Number: 4137
No competition. I whould take the Orion 250g4 in a heartbeat.
Home > Message Board > Car Audio > Amplifiers > Archive through December 17, 2006 > HCCA 250G4 vs. Memphis MC1000 [ « Previous ] [ Next » ]
